[MPC5746C][HSM] Regarding generating new BOOT_MAC
Question asked by Namwook KIM on Jan 24, 2018
Dear Sir,
I implemented the code that generate new BOOT_MAC by referring to section "2.10.3. Method 1: Use the LOAD_RAM_KEY command and HSM to generate the new BOOT_MAC" in AN5178, and then updated the BOOT_MAC memory slot, key id is 3, by using memory update protocol.
I could see there are two old and new key blocks have same key id on HSM Key area like the bellow.
I think the old slot should be updated and this symptom is incorrect.
Could you please confirm whether this symptom is incorrect or not?
Thanks and regards,
Namwook
