How to confirm MAC-Layer ACK?(JN5169,JN-SW-4168)
teddyzheng
I send no-aps-ack package, like 'eCLD_IASZoneUpdateZoneStatus' (defined CLD_IASZONE_BOUND_TX_WITH_APS_ACK_DISABLED).
but i need get next-hop MAC-Layer ACK to confirm it's parent node is received this package.
i do not found any callback event in 'ZPS_teAfEventType'.
how to confirm MAC-Layer ACK?
Thanks!
teddyzheng
Hello?
Can you give me some advice?
mario_castaneda
Hi Teddy,
What are the Application note and the version that you are working on?
Mario
teddyzheng
Hi Mario,
Thanks for your reply!
sorry, I don't understand the mean of "Application note and the version"
My product is a battery sleepping device(a sensor), base on ZHA1.2 and JN-SW-4168v1620.
when it send a no-aps-ack command(like report, or IAS Status Change Notification, etc), it's parent node will response mac-layer ack, I want to check it. if no response, the sensor need do re-send command, or send beacon request to searching the new parent node.
but I don't known how to check mac-layer ack.
mario_castaneda
Hi Teddy,
You are working on the Home Automation, so did you take as a reference an Application note ?
Mario
