bootloader for K70
bootloader for K70
johnatkins
We would like to reprogram a Kinetis K70 from UART4 on the K70. This is a way to implement a firmware upgrade. Does anyone have anything like this, or any advice?
Thank You.
John
merigotbertrand
Hello john,
I just finish to debug a bootloader for a KV46,
In the original version, the Bootloader is very powerfull, it's scanning all the possible link (as a slave)
I2C,SPI, CAN and UART
You can use any uart you want you only have to modify the original version 2.0.0 to adapt it to you hardware.
check the files :
Hardware_init_Kxx.C files.
Peripherals_Kxx.C files
Peripheral_pinmux.h
No modification needed for kinetisflashtools
regards
bertrand
Hui_Ma
Hi John,
Please refer below links for the serial bootloader for K70 product:
https://www.nxp.com/docs/en/application-note/AN2295.pdf
Developer’s Serial Bootloader.
https://community.nxp.com/docs/DOC-330712
Wish it helps.
Mike
