Can I use raspberry pi for video processing and use the required output as a command to FRDM-K64F microcontroller?
balajiv
I want to process the traffic signs using open computer vision.Since raspberry pi is fast in image processing,will I be able to interface raspberry pi with FRDM-K64F microcontroller ?
jingpan
 There isn't offical reference design on how to connect FRDM-K64F with raspberry pi. But I think it is not a hard job. Both borads have plenty of interface, I2C,SPI, UART, USB, CAN... So it is depend on your usage.
Jing
