Cannot find "e_li" in e200z4RM.pdf
zhanglei327
I cannot find e_li in e200z4RM.pdf. Where can I find it? Im using SPC5646B. Thank you!
martin_kovar
please check the document in the post attachment.
Martin
martin_kovar
Martin
zhanglei327
I cannot find the "mtlr" in "VLEPEM.pdf", but I find the "se_mtlr" in "VLEPEM.pdf". Are they same? Thank you!
martin_kovar
instructions which starts with e_ or se_ are from VLE instruction set. Instructions without e_ or se_ are BookE instructions.
For more information about BookE instructions, please check the document in the attachment.
Martin
zhanglei327
I searched the "mtlr" in the "EREFRM_2-0.pdf", but I still cannot find it. Thank you!
martin_kovar
sorry my mistake. In BookE, there is only mtspr instruction, so it seems mtlr is alias to mtspr instruction, because Link register is also marked as spr x register.
Instruction mtld loads data to link register as well as se_mtlr.
Martin
zhanglei327
mtlr only has one parameter, but mtspr has two parameter. Thank you!
martin_kovar
As I wrote you before. mtlr is only mnemonic to mtspr instruction. Please check for example the link below:
PowerPC Instruction Set: mtspr
Martin
