How to map values of Output Power in Connectivity Test Application
Question asked by Vishnu Beema on Jan 14, 2018
Latest reply on Jan 16, 2018 by Estephania Martinez Garcia
In SMAC “Kinetis SMAC Demo Applications User's Guide.pdf” under “Chapter 4 Kinetis Connectivity Test Application” there is an option to change the output power value. But its mentioned to see corresponding reference manual. From where I can find this mapping between the register value and the converted dBm value.
  • ‘s’ : decrements output power value. If output power is at minimum and this key is pressed, the output power will go to maximum (in this case 0x1C). These are not directly mapped to dBm values. Instead the output power value is written to the appropriate register. The user should consult the reference manual to determine the relationship between selected value and power in dBm.
Thanks & Regards
Vishnu Beema
