How to write data to DFLASH. Use the JLINK tool in the S32DS software.
wenhongkui
I set some data in the DFLASH area. I check the S19 file, the data address is correct, but after I use the JLINK download program in S32DS, I find that the data of the DFLASH is empty from the chip. Do you need to make some settings? What should I do?
