Error when import SDK zip into MCUXpresso IDE
Fan_xy
CUXpresso IDE v10.1.0 [Build 589] [2017-11-14]
and also
MCUXpressoIDE_10.1.1_606.exe
FRDM-K64-AGM04 SDKv2.3
my system is win10 pro.
When import the SDK zip package into MCUXpresso IDE, it shows erro :
What am I missing ?
(I have submit the same question on this thread https://community.nxp.com/thread/466986 )
Thank you very much!
Fan
lpcxpresso_supp
What is your exact username on your PC? The username is used by the IDE to provide the location used to install part support information extracted from the SDK. From the errors you are seeing we suspect your issues is related to "an unusual character", maybe an "&", in your username.
In which case, the only workaround we can think of for the moment is to use the IDE under an alternative username.
I apologise for the inconvenience and we will look into solving this issue in a future release.
MCUXpresso IDE Support
