PA MCP8378 flash programming with CW-SUITE-BASIC
Question asked by Yan Davidov on Jan 14, 2018
Latest reply on Jan 21, 2018 by Yiping Wang
Hi, i have purchase the basic suite 10.5x and the codewarrior TAP, for one purpose - flash programming.
I have project which is working on professional suite 5.9 and codewarrior USB TAP ( old project old hardware).
I want to setup this project on 10.5 suite and codewarrior TAP, do i have to create new configuration files?
I follow the guide for flash programming (Document Number: AN4948 - Flash Programmer for CodeWarrior Power
Architecture) but no results.
attached prints screens and configuration files:
the "ddrabi_837xrdb_init.cfg" go to the memory configuration place
the "flash_prog_config_word_A0._test_foo40000.tcl" go to the Initialize target
the "8377 abi_configuration_word.txt" go to target type.
The CWTAP does connect to the 8378 you can see it in "run configuraton pic1" but than error appear as in "run configuration pic2".
Please look at license log file for unsupported features.
( according the CW-SUITE-BASIC overview it should support flash programming.
See attached file: PA - flash supported device families (83xx)
CW-SUITE-BASIC )
what do i need to do to perform flash programming?
