I currently have a conflict between four pins in the Pins Tool utility for a project am working on. Our design is similar to the Sabre board for these particular pins, so I wanted to compare my pin configurations to ones that work for the Sabre board. Is there a .mex file available that I can use to check the configuration of these pins?
The particular pins of interest are D22, U21, B23 and W22.
You may create .mex file for the MCIMX6Q-SDB, using the Pins tool.
The attached is file of Pins v.4.
Yuri
