imx6q 导航黑屏
imx6q 导航黑屏
xiaojunye
我的板子是imx6q,运行android4.4.2,内核版本为:3.0.35。
现在运行导航时会偶尔黑屏,系统没死。
部分log如下:
01-11 11:08:37.967 3648-3648/com.itas.klong E/DEBUG_FAN: =====Nav onPause
01-11 11:08:37.967 3648-3866/com.itas.klong D/MscSpeechLog: QTTSSessionEnd enter
01-11 11:08:37.967 3648-3866/com.itas.klong D/MSC_LOG: QTTSSessionEnd Begin
01-11 11:08:37.977 3648-3866/com.itas.klong D/MSC_LOG: QTTSSessionEnd End
01-11 11:08:37.977 3648-3866/com.itas.klong D/MscSpeechLog: QTTSSessionEnd leavel:0
01-11 11:08:37.977 3648-3866/com.itas.klong D/MscSpeechLog: curStatus=exiting,setStatus=exited
01-11 11:08:37.977 3648-3866/com.itas.klong D/MscSpeechLog: setStatus success=exited
01-11 11:08:37.977 3648-3866/com.itas.klong D/MscSpeechLog: clear all message
01-11 11:08:37.977 3648-3866/com.itas.klong D/MscSpeechLog: MscSynthesizer#onCancel
01-11 11:08:37.977 3648-3866/com.itas.klong D/MscSpeechLog: quit current Msc Handler thread
01-11 11:08:37.987 3648-3648/com.itas.klong E/DEBUG_FAN: =====map onResume
01-11 11:08:38.047 2749-2957/system_process W/LocationManagerService: Dropping incomplete location: Location[gps 0.000000,0.000000 acc=??? t=?!? et=?!? {Bundle[{satellites=0}]}]
01-11 11:08:38.317 3648-3648/com.itas.klong W/View: requestLayout() improperly called by android.support.v7.widget.AppCompatTextView{42003558 V.ED.... ........ 0,0-157,59 #7f080207 app:id/tabView} during second layout pass: posting in next frame
01-11 11:08:38.337 3648-3648/com.itas.klong W/View: requestLayout() improperly called by android.support.v7.widget.AppCompatTextView{42003558 V.ED.... ......ID 0,0-157,59 #7f080207 app:id/tabView} during layout: running second layout pass
01-11 11:08:38.347 3160-3160/? I/floodinfo: poll() returned 0
01-11 11:08:38.347 3160-3160/? I/floodinfo: usb_process dev_poll_remain_ms
01-11 11:08:38.347 3160-3160/? I/floodinfo: usb_discover: scanning 3 devices
01-11 11:08:38.347 3160-3160/? I/floodinfo: usb_discover reap_dead_devices
01-11 11:08:38.347 3160-3160/? I/floodinfo: usb_discover libusb_free_device_list
01-11 11:08:38.347 3160-3160/? I/floodinfo: usb_discover ************pairFailed! StopProxy**********
01-11 11:08:38.347 3160-3160/? I/floodinfo: usb_discover valid_count is 0
01-11 11:08:38.347 3160-3160/? I/floodinfo: usb_process usb_discover return 0
01-11 11:08:38.347 3160-3160/? I/floodinfo: usb_process return 0
01-11 11:08:38.347 3160-3160/? I/floodinfo: main_loop iteration
01-11 11:08:38.347 3160-3160/? I/floodinfo: USB timeout is 1000 ms
01-11 11:08:38.347 3160-3160/? I/floodinfo: Device timeout is 1000 ms
01-11 11:08:38.347 3160-3160/? I/floodinfo: fd count is 2
01-11 11:08:38.367 3648-3648/com.itas.klong E/DEBUG_FAN: =====Nav onDestroy
01-11 11:08:38.417 3648-3834/com.itas.klong E/libEGL: call to OpenGL ES API with no current context (logged once per thread)
01-11 11:08:38.457 3648-3836/com.itas.klong W/System.err: java.lang.NullPointerException
01-11 11:08:38.457 3648-3836/com.itas.klong W/System.err: at com.amap.api.col.sln3.cw.a(MarkerDelegateImp.java:1208)
01-11 11:08:38.457 3648-3836/com.itas.klong W/System.err: at com.amap.api.col.sln3.cw.setGeoPoint(MarkerDelegateImp.java:1198)
01-11 11:08:38.457 3648-3836/com.itas.klong W/System.err: at com.amap.api.maps.model.Marker.setGeoPoint(Marker.java:475)
01-11 11:08:38.457 3648-3836/com.itas.klong W/System.err: at com.amap.api.col.sln3.fv.a(NaviCarOverlay.java:40)
01-11 11:08:38.457 3648-3836/com.itas.klong W/System.err: at com.amap.api.col.sln3.fv$1.run(NaviCarOverlay.java:304)
01-11 11:08:38.457 3648-3836/com.itas.klong W/System.err: at java.util.Timer$TimerImpl.run(Timer.java:284)
01-11 11:08:38.507 3648-3836/com.itas.klong W/System.err: java.lang.NullPointerException
01-11 11:08:38.507 3648-3836/com.itas.klong W/System.err: at com.amap.api.col.sln3.cw.a(MarkerDelegateImp.java:1208)
01-11 11:08:38.507 3648-3836/com.itas.klong W/System.err: at com.amap.api.col.sln3.cw.setGeoPoint(MarkerDelegateImp.java:1198)
01-11 11:08:38.507 3648-3836/com.itas.klong W/System.err: at com.amap.api.maps.model.Marker.setGeoPoint(Marker.java:475)
01-11 11:08:38.507 3648-3836/com.itas.klong W/System.err: at com.amap.api.col.sln3.fv.a(NaviCarOverlay.java:40)
01-11 11:08:38.507 3648-3836/com.itas.klong W/System.err: at com.amap.api.col.sln3.fv$1.run(NaviCarOverlay.java:304)
01-11 11:08:38.507 3648-3836/com.itas.klong W/System.err: at java.util.Timer$TimerImpl.run(Timer.java:284)
01-11 11:08:38.737 3648-3648/com.itas.klong D/MscSpeechLog: isSpeaking enter
01-11 11:08:38.737 3648-3648/com.itas.klong D/MscSpeechLog: isSpeaking leave
01-11 11:08:38.737 3648-3648/com.itas.klong D/MscSpeechLog: stopSpeaking enter:false
01-11 11:08:38.737 3648-3648/com.itas.klong D/MscSpeechLog: stopSpeaking leave
01-11 11:08:38.737 3648-3648/com.itas.klong D/MscSpeechLog: Destory tts engine.
01-11 11:08:38.737 3648-3648/com.itas.klong D/MSC_LOG: QMSPSetParam Begin
01-11 11:08:38.737 3648-3648/com.itas.klong D/MSC_LOG: QMSPSetParam End
01-11 11:08:38.777 3648-3648/com.itas.klong W/View: requestLayout() improperly called by android.support.v7.widget.AppCompatTextView{42003558 V.ED.... ........ 0,0-157,59 #7f080207 app:id/tabView} during second layout pass: posting in next frame
01-11 11:08:38.787 3648-3648/com.itas.klong W/View: requestLayout() improperly called by android.support.v7.widget.AppCompatTextView{42003558 V.ED.... ......ID 0,0-157,59 #7f080207 app:id/tabView} during layout: running second layout pass
01-11 11:08:38.797 3648-3834/com.itas.klong E/CrashReport-Native: Failed to get JNIEnv.
01-11 11:08:38.797 3648-3834/com.itas.klong A/libc: Fatal signal 7 (SIGBUS) at 0x00000000 (code=128), thread 3834 (Thread-409)
01-11 11:08:38.847 2345-2345/? I/DEBUG: *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
01-11 11:08:38.847 2345-2345/? I/DEBUG: Build fingerprint: 'Freescale/sabresd_6dq/sabresd_6dq:4.4.2/1.0.0-rc3/20140630:eng/dev-keys'
01-11 11:08:38.847 2345-2345/? I/DEBUG: Revision: '405525'
01-11 11:08:38.847 2345-2345/? I/DEBUG: pid: 3648, tid: 3834, name: Thread-409 >>> com.itas.klong <<<
01-11 11:08:38.847 2345-2345/? I/DEBUG: signal 7 (SIGBUS), code 128 (SI_KERNEL), fault addr 00000000
01-11 11:08:38.987 2345-2345/? I/DEBUG: r0 6c183788 r1 00000102 r2 00000001 r3 00000000
01-11 11:08:38.987 2345-2345/? I/DEBUG: r4 6c183788 r5 00000000 r6 688c9931 r7 834b97c0
01-11 11:08:38.987 2345-2345/? I/DEBUG: r8 400ca538 r9 400ca2f0 sl 7b914dd0 fp 400ca2f0
01-11 11:08:38.987 2345-2345/? I/DEBUG: ip 00000001 sp 7b914d38 lr 688c8a79 pc 689130dc cpsr 60070030
01-11 11:08:38.987 2345-2345/? I/DEBUG: d0 0000000000000000 d1 0000000000000000
01-11 11:08:38.987 2345-2345/? I/DEBUG: d2 0000000000000000 d3 0000000000000000
01-11 11:08:38.987 2345-2345/? I/DEBUG: d4 0000000000000000 d5 0008000000000000
01-11 11:08:38.987 2345-2345/? I/DEBUG: d6 0008001008010588 d7 0000000000000000
01-11 11:08:38.987 2345-2345/? I/DEBUG: d8 0000000000000000 d9 400000003f000000
01-11 11:08:38.987 2345-2345/? I/DEBUG: d10 3ff921fb54442d18 d11 404ca5dc1a63c1f8
01-11 11:08:38.987 2345-2345/? I/DEBUG: d12 41683659c4a14bbc d13 405c822f50000002
01-11 11:08:38.987 2345-2345/? I/DEBUG: d14 404ca5dc1a63c1f8 d15 4000000000000000
01-11 11:08:38.987 2345-2345/? I/DEBUG: d16 0000000000504e10 d17 0000000000000108
01-11 11:08:38.987 2345-2345/? I/DEBUG: d18 0000000000504d08 d19 0000000000000000
01-11 11:08:38.987 2345-2345/? I/DEBUG: d20 bf2a0189de2f970c d21 3c39d9ccf0000000
01-11 11:08:38.987 2345-2345/? I/DEBUG: d22 3ec71de357b1fe7d d23 bfc549536d6e83d6
01-11 11:08:38.987 2345-2345/? I/DEBUG: d24 bf29fcf71f0c8eca d25 3fcaa515366b5637
01-11 11:08:38.987 2345-2345/? I/DEBUG: d26 bc55000000000000 d27 bf56bc084e9425c6
01-11 11:08:38.987 2345-2345/? I/DEBUG: d28 3feffc273cf0637e d29 3fcad754a22168c0
01-11 11:08:38.987 2345-2345/? I/DEBUG: d30 3fd55849a1fc3590 d31 3ff921fb54442d18
01-11 11:08:38.987 2345-2345/? I/DEBUG: scr 80000013
01-11 11:08:38.987 2345-2345/? I/DEBUG: backtrace:
01-11 11:08:38.987 2345-2345/? I/DEBUG: #00 pc 000830dc /system/lib/libGAL.so
01-11 11:08:38.987 2345-2345/? I/DEBUG: #01 pc 000863d9 /system/lib/libGAL.so
01-11 11:08:38.987 2345-2345/? I/DEBUG: #02 pc 000399a9 /system/lib/libGAL.so
01-11 11:08:38.987 2345-2345/? I/DEBUG: #03 pc 0000d720 /system/lib/libc.so
01-11 11:08:38.987 2345-2345/? I/DEBUG: #04 pc 0000ee80 /system/lib/libc.so (pthread_exit+80)
01-11 11:08:38.987 2345-2345/? I/DEBUG: #05 pc 0000d3e0 /system/lib/libc.so (pthread_create+240)
01-11 11:08:38.987 2345-2345/? I/DEBUG: stack:
01-11 11:08:38.987 2345-2345/? I/DEBUG: 7b914cf8 4453b7ad /dev/ashmem/dalvik-heap (deleted)
01-11 11:08:38.987 2345-2345/? I/DEBUG: 7b914cfc 834b97c0
01-11 11:08:38.987 2345-2345/? I/DEBUG: 7b914d00 685cb780
01-11 11:08:38.987 2345-2345/? I/DEBUG: 7b914d04 00000000
01-11 11:08:38.987 2345-2345/? I/DEBUG: 7b914d08 4453b7ad /dev/ashmem/dalvik-heap (deleted)
01-11 11:08:38.987 2345-2345/? I/DEBUG: 7b914d0c 688c8a79 /system/lib/libGAL.so (gcoOS_ReleaseMutex+8)
01-11 11:08:38.987 2345-2345/? I/DEBUG: 7b914d10 00000000
01-11 11:08:38.987 2345-2345/? I/DEBUG: 7b914d14 688b99db /system/lib/libGAL.so
01-11 11:08:38.987 2345-2345/? I/DEBUG: 7b914d18 68928ee8 /system/lib/libGAL.so
01-11 11:08:38.987 2345-2345/? I/DEBUG: 7b914d1c 6c183788
01-11 11:08:38.987 2345-2345/? I/DEBUG: 7b914d20 00000000
01-11 11:08:38.997 2345-2345/? I/DEBUG: 7b914d24 688c9931 /system/lib/libGAL.so
01-11 11:08:38.997 2345-2345/? I/DEBUG: 7b914d28 834b97c0
01-11 11:08:38.997 2345-2345/? I/DEBUG: 7b914d2c 688c84d5 /system/lib/libGAL.so (gcoOS_AtomDestroy+20)
01-11 11:08:38.997 2345-2345/? I/DEBUG: 7b914d30 00000010
01-11 11:08:38.997 2345-2345/? I/DEBUG: 7b914d34 689130cf /system/lib/libGAL.so
01-11 11:08:38.997 2345-2345/? I/DEBUG: #00 7b914d38 6c183788
01-11 11:08:38.997 2345-2345/? I/DEBUG: 7b914d3c 689163dd /system/lib/libGAL.so
01-11 11:08:38.997 2345-2345/? I/DEBUG: #01 7b914d40 834b97c0
01-11 11:08:38.997 2345-2345/? I/DEBUG: 7b914d44 400ca538 /system/lib/libc.so
01-11 11:08:38.997 2345-2345/? I/DEBUG: 7b914d48 400ca2f0 /system/lib/libc.so
01-11 11:08:38.997 2345-2345/? I/DEBUG: 7b914d4c 834b97c0
01-11 11:08:38.997 2345-2345/? I/DEBUG: 7b914d50 00000001
01-11 11:08:38.997 2345-2345/? I/DEBUG: 7b914d54 688c99ad /system/lib/libGAL.so
01-11 11:08:38.997 2345-2345/? I/DEBUG: #02 7b914d58 00000000
01-11 11:08:38.997 2345-2345/? I/DEBUG: 7b914d5c 00000018
01-11 11:08:38.997 2345-2345/? I/DEBUG: 7b914d60 400ca34c /system/lib/libc.so
01-11 11:08:38.997 2345-2345/? I/DEBUG: 7b914d64 4008b724 /system/lib/libc.so
01-11 11:08:38.997 2345-2345/? I/DEBUG: memory near r0:
01-11 11:08:38.997 2345-2345/? I/DEBUG: 6c183768 00001000 00000001 00000001 00000000
01-11 11:08:38.997 2345-2345/? I/DEBUG: 6c183778 6c186408 7c7d2000 0d627000 00000000
01-11 11:08:38.997 2345-2345/? I/DEBUG: 6c183788 00000020 00000000 0000004f 00000000
01-11 11:08:38.997 2345-2345/? I/DEBUG: 6c183798 0000004e 7b6318e0 00000001 00000000
01-11 11:08:38.997 2345-2345/? I/DEBUG: 6c1837a8 00000048 00000000 3d5ae111 3f2b9fd1
01-11 11:08:38.997 2345-2345/? I/DEBUG: 6c1837b8 00000000 00000000 3e80b7dd be11eb60
01-11 11:08:38.997 2345-2345/? I/DEBUG: 6c1837c8 00000000 00000000 00000000 3db3a62d
01-11 11:08:38.997 2345-2345/? I/DEBUG: 6c1837d8 be8b154c be86bca2 43bb24c5 c4f6fa92
01-11 11:08:38.997 2345-2345/? I/DEBUG: 6c1837e8 00000000 446a66ca 00000128 00000000
01-11 11:08:38.997 2345-2345/? I/DEBUG: 6c1837f8 08030202 00000102 00000003 00000100
01-11 11:08:38.997 2345-2345/? I/DEBUG: 6c183808 08010217 00060000 0801020e 00000000
01-11 11:08:38.997 2345-2345/? I/DEBUG: 6c183818 08010200 00000007 081c3000 01821009
01-11 11:08:38.997 2345-2345/? I/DEBUG: 6c183828 00000000 00000000 003f8008 01801002
01-11 11:08:38.997 2345-2345/? I/DEBUG: 6c183838 15002800 00000240 0015000a 07821003
01-11 11:08:38.997 2345-2345/? I/DEBUG: 6c183848 39000800 00000050 00000000 07801002
01-11 11:08:38.997 2345-2345/? I/DEBUG: 6c183858 39001800 00aa0050 00390028 07801001
01-11 11:08:38.997 2345-2345/? I/DEBUG: memory near r4:
01-11 11:08:39.007 2345-2345/? I/DEBUG: 6c1837f8 08030202 00000102 00000003 00000100
01-11 11:08:39.007 2345-2345/? I/DEBUG: 6c183808 08010217 00060000 0801020e 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 6c183818 08010200 00000007 081c3000 01821009
01-11 11:08:39.007 2345-2345/? I/DEBUG: 6c183828 00000000 00000000 003f8008 01801002
01-11 11:08:39.007 2345-2345/? I/DEBUG: 6c183838 15002800 00000240 0015000a 07821003
01-11 11:08:39.007 2345-2345/? I/DEBUG: 6c183848 39000800 00000050 00000000 07801002
01-11 11:08:39.007 2345-2345/? I/DEBUG: 6c183858 39001800 00aa0050 00390028 07801001
01-11 11:08:39.007 2345-2345/? I/DEBUG: memory near r6:
01-11 11:08:39.007 2345-2345/? I/DEBUG: 688c9910 0005f6b2 0005f68c 0005f666 0005f640
01-11 11:08:39.007 2345-2345/? I/DEBUG: 688c9920 0005f62e 0005f612 0005f60a 000713b0
01-11 11:08:39.007 2345-2345/? I/DEBUG: 688c9930 4601b538 46044b32 6818447b eda2f7d1
01-11 11:08:39.007 2345-2345/? I/DEBUG: 688c9940 28006ae0 69a1d152 4620b119 22004788
01-11 11:08:39.007 2345-2345/? I/DEBUG: 688c9950 6a2061a2 f019b118 2300fa03 6aa06223
01-11 11:08:39.007 2345-2345/? I/DEBUG: 688c9960 f7f3b118 2000fff1 686062a0 6825b138
01-11 11:08:39.007 2345-2345/? I/DEBUG: 688c9970 60212101 ffcaf7da 60252200 68a06062
01-11 11:08:39.007 2345-2345/? I/DEBUG: 688c9980 6825b138 60232302 ffc0f7da 60252000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 688c9990 692060a0 f7fab118 2100fc5d 68e06121
01-11 11:08:39.007 2345-2345/? I/DEBUG: 688c99a0 6825b138 60222204 fd04f04c 60252300
01-11 11:08:39.007 2345-2345/? I/DEBUG: 688c99b0 462060e3 ed72f7d1 c048f8df 44fc2100
01-11 11:08:39.007 2345-2345/? I/DEBUG: 688c99c0 0000f8dc ed5ef7d1 4478480f b1636bc3
01-11 11:08:39.007 2345-2345/? I/DEBUG: 688c99d0 8f5ff3bf 2f00e853 e8431e50 29000100
01-11 11:08:39.007 2345-2345/? I/DEBUG: 688c99e0 2a01d1f8 8f5ff3bf bd38d006 21004620
01-11 11:08:39.007 2345-2345/? I/DEBUG: 688c99f0 f7d12230 e7a6ecb8 4038e8bd bf08f7ff
01-11 11:08:39.007 2345-2345/? I/DEBUG: 688c9a00 0007135c 000712d6 0005f51a b5104b06
01-11 11:08:39.007 2345-2345/? I/DEBUG: memory near r7:
01-11 11:08:39.007 2345-2345/? I/DEBUG: 834b97a0 41900000 3dcd7b80 3f800000 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 834b97b0 00000000 00000000 00000268 00000042
01-11 11:08:39.007 2345-2345/? I/DEBUG: 834b97c0 00000004 00000000 00000000 6c183788
01-11 11:08:39.007 2345-2345/? I/DEBUG: 834b97d0 00000000 00000000 00000000 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 834b97e0 00000000 00000001 00000000 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 834b97f0 0064006e 0077006f 00000040 0000002b
01-11 11:08:39.007 2345-2345/? I/DEBUG: 834b9800 00000000 40000104 ca69b5f3 00000008
01-11 11:08:39.007 2345-2345/? I/DEBUG: 834b9810 5f746567 74736f68 6e002000 7463656e
01-11 11:08:39.007 2345-2345/? I/DEBUG: 834b9820 3a6e6f69 0000001b 815cd120 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 834b9830 0000000b 000001a6 00000018 0000002b
01-11 11:08:39.007 2345-2345/? I/DEBUG: 834b9840 00000000 40000104 6c4ac3e8 00000005
01-11 11:08:39.007 2345-2345/? I/DEBUG: 834b9850 6d697464 00000065 827fa670 820f69f0
01-11 11:08:39.007 2345-2345/? I/DEBUG: 834b9860 00000028 00001159 7a5a13a8 82106d90
01-11 11:08:39.007 2345-2345/? I/DEBUG: 834b9870 00000000 00000000 00000000 00000008
01-11 11:08:39.007 2345-2345/? I/DEBUG: 834b9880 00000000 00000000 40338d55 40338d5f
01-11 11:08:39.007 2345-2345/? I/DEBUG: 834b9890 00000000 00000000 00000001 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: memory near r8:
01-11 11:08:39.007 2345-2345/? I/DEBUG: 400ca518 00000000 00000000 00000000 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 400ca528 00000000 00000000 00000000 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 400ca538 00000000 00000000 00000002 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 400ca548 00000001 00000000 00000000 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 400ca558 00000000 00000000 00000000 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 400ca568 00000000 00000000 00000000 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 400ca578 00000000 00000000 00000000 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 400ca588 00000000 00000000 00000000 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 400ca598 00000000 00000000 00000000 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 400ca5a8 00000000 00000000 00000000 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 400ca5b8 00000000 00000000 00000000 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 400ca5c8 00000000 00000000 00000000 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 400ca5d8 00000000 00000000 00000000 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 400ca5e8 00000000 00000000 00000000 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 400ca5f8 00000000 00000000 00000000 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: 400ca608 00000000 00000000 00000000 00000000
01-11 11:08:39.007 2345-2345/? I/DEBUG: memory near r9:
01-11 11:08:39.007 2345-2345/? I/DEBUG: 400ca2d0 00000000 00000000 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 400ca2e0 00000000 ffffffff 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 400ca2f0 00000001 ffffffff 00000001 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 400ca300 00000000 00000000 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 400ca310 00000000 00000000 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 400ca320 00000000 40090b25 40090b21 400914d3
01-11 11:08:39.017 2345-2345/? I/DEBUG: 400ca330 4009160d 00000000 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 400ca340 00000000 4169b145 400916a1 4050adb5
01-11 11:08:39.017 2345-2345/? I/DEBUG: 400ca350 00000000 00000000 00000000 401ad3ed
01-11 11:08:39.017 2345-2345/? I/DEBUG: 400ca360 400e8de1 688c9931 403590a9 6a1c9315
01-11 11:08:39.017 2345-2345/? I/DEBUG: 400ca370 68dcbd0d 68d35c21 68f17ead 6a622929
01-11 11:08:39.017 2345-2345/? I/DEBUG: 400ca380 6a2396e5 6a3b4aa1 6a1a2ead 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 400ca390 00000000 00000000 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 400ca3a0 00000000 00000000 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 400ca3b0 00000000 00000000 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 400ca3c0 00000000 00000000 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: memory near sl:
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914db0 4169d1ed 834e4a38 7b914dd0 00000002
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914dc0 00000078 4169d1ed beda62f4 4008b3e4
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914dd0 7b914dd0 834e4a38 00000002 4039e844
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914de0 00000000 8324ed2a 834e4a78 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914df0 00000000 00000000 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914e00 00000000 00000000 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914e10 00000000 00000000 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914e20 00000000 00000000 00000000 834b97c0
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914e30 68a5d118 00000000 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914e40 00000000 00000000 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914e50 00000000 00000000 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914e60 00000000 00000000 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914e70 00000000 00000000 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914e80 00000000 00000000 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914e90 00000000 00000000 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914ea0 00000000 00000000 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: memory near fp:
01-11 11:08:39.017 2345-2345/? I/DEBUG: 400ca2d0 00000000 00000000 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: memory near sp:
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914d18 68928ee8 6c183788 00000000 688c9931
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914d28 834b97c0 688c84d5 00000010 689130cf
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914d38 6c183788 689163dd 834b97c0 400ca538
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914d48 400ca2f0 834b97c0 00000001 688c99ad
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914d58 00000000 00000018 400ca34c 4008b724
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914d68 416f7500 00000001 00000004 400ca2f0
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914d78 00000001 834e4a38 00000000 00000000
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914d88 000fe000 7b817000 7b817000 beda62f4
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914d98 400ca2ec 4008ce84 7b914dd0 834e4a38
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914da8 4169d1ed 8163e4d8 4169d1ed 834e4a38
01-11 11:08:39.017 2345-2345/? I/DEBUG: 7b914db8 7b914dd0 00000002 00000078 4169d1ed
01-11 11:08:39.027 2345-2345/? I/DEBUG: 7b914dc8 beda62f4 4008b3e4 7b914dd0 834e4a38
01-11 11:08:39.027 2345-2345/? I/DEBUG: 7b914dd8 00000002 4039e844 00000000 8324ed2a
01-11 11:08:39.027 2345-2345/? I/DEBUG: 7b914de8 834e4a78 00000000 00000000 00000000
01-11 11:08:39.027 2345-2345/? I/DEBUG: 7b914df8 00000000 00000000 00000000 00000000
01-11 11:08:39.027 2345-2345/? I/DEBUG: 7b914e08 00000000 00000000 00000000 00000000
01-11 11:08:39.027 2345-2345/? I/DEBUG: code around pc:
01-11 11:08:39.027 2345-2345/? I/DEBUG: 689130bc e6624481 4604b510 b1316e01 f7b56880
01-11 11:08:39.027 2345-2345/? I/DEBUG: 689130cc 2800f9f9 2300db0e 6f616623 4620b149
01-11 11:08:39.027 2345-2345/? I/DEBUG: 689130dc 2302e9d1 ff06f002 db032800 67602000
01-11 11:08:39.027 2345-2345/? I/DEBUG: 689130ec 4608bd10 bf00bd10 b083b5f0 46684c1a
01-11 11:08:39.027 2345-2345/? I/DEBUG: 689130fc fe8af7b5 2800447c 9900db21 2d0068cd
01-11 11:08:39.027 2345-2345/? I/DEBUG: 6891310c 6eecd01f 1c612000 4628d010 6fae6f69
01-11 11:08:39.027 2345-2345/? I/DEBUG: 6891311c f8b4f001 db122800 68622700 68a16823
01-11 11:08:39.027 2345-2345/? I/DEBUG: 6891312c f84660a7 1c4a2023 d1f6460c 6e696f2a
01-11 11:08:39.027 2345-2345/? I/DEBUG: 6891313c 66ea6eab 32fff04f 672a66a9 b003666b
01-11 11:08:39.027 2345-2345/? I/DEBUG: 6891314c 4b06bdf0 58e0310c f0006840 2800fa37
01-11 11:08:39.027 2345-2345/? I/DEBUG: 6891315c 9900dbf5 e7d468cd 00014d60 ffffffd8
01-11 11:08:39.027 2345-2345/? I/DEBUG: 6891316c b082b570 4616460c 4d224668 fe4cf7b5
01-11 11:08:39.027 2345-2345/? I/DEBUG: 6891317c 2800447d 9900db1a b1cb68cb 42a26dda
01-11 11:08:39.027 2345-2345/? I/DEBUG: 6891318c 6d98d313 d4101a24 0444eb04 00a46e9a
01-11 11:08:39.027 2345-2345/? I/DEBUG: 6891319c 59121911 6888b14a 6d1bb1b8 684ab113
01-11 11:08:39.027 2345-2345/? I/DEBUG: 689131ac d01042b2 2007604e 2007e000 bd70b002
01-11 11:08:39.027 2345-2345/? I/DEBUG: code around lr:
01-11 11:08:39.027 2345-2345/? I/DEBUG: 688c8a58 eca2f7d2 bf0c2800 f06f2000 bd380006
01-11 11:08:39.027 2345-2345/? I/DEBUG: 688c8a68 000ef06f bf00bd38 4608b508 ecbef7d2
01-11 11:08:39.027 2345-2345/? I/DEBUG: 688c8a78 bd082000 2001b508 f44fb119 fb00707a
01-11 11:08:39.027 2345-2345/? I/DEBUG: 688c8a88 f7d2f001 2000ed98 bf00bd08 4614b510
01-11 11:08:39.027 2345-2345/? I/DEBUG: 688c8a98 ed96f7d2 20006020 bf00bd10 4614b510
01-11 11:08:39.027 2345-2345/? I/DEBUG: 688c8aa8 ed94f7d2 20006020 bf00bd10 460cb538
01-11 11:08:39.027 2345-2345/? I/DEBUG: 688c8ab8 1e624611 f7d24605 192ced90 46182300
01-11 11:08:39.027 2345-2345/? I/DEBUG: 688c8ac8 3c01f804 bf00bd38 460cb570 46164605
01-11 11:08:39.027 2345-2345/? I/DEBUG: 688c8ad8 ec5cf7d2 46034284 1e62d909 1828192c
01-11 11:08:39.027 2345-2345/? I/DEBUG: 688c8ae8 1ad24631 ed78f7d2 f8042000 20000c01
01-11 11:08:39.027 2345-2345/? I/DEBUG: 688c8af8 bf00bd70 f7d2b508 2800ec5c dd01d003
01-11 11:08:39.027 2345-2345/? I/DEBUG: 688c8b08 bd082009 bd08200a f7d2b508 2800ec34
01-11 11:08:39.027 2345-2345/? I/DEBUG: 688c8b18 dd01d003 bd082009 bd08200a 460cb510
01-11 11:08:39.027 2345-2345/? I/DEBUG: 688c8b28 f7d22100 ec41ed60 eef70b30 20007be0
01-11 11:08:39.027 2345-2345/? I/DEBUG: 688c8b38 7a00edc4 bf00bd10 4903460a 4479b508
01-11 11:08:39.027 2345-2345/? I/DEBUG: 688c8b48 ed56f7d2 bd082000 00055592 ed2db530
01-11 11:08:39.047 2749-2957/system_process W/LocationManagerService: Dropping incomplete location: Location[gps 0.000000,0.000000 acc=??? t=?!? et=?!? {Bundle[{satellites=0}]}]
01-11 11:08:39.347 3160-3160/? I/floodinfo: poll() returned 0
01-11 11:08:39.347 3160-3160/? I/floodinfo: usb_process dev_poll_remain_ms
01-11 11:08:39.347 3160-3160/? I/floodinfo: usb_discover: scanning 3 devices
01-11 11:08:39.347 3160-3160/? I/floodinfo: usb_discover reap_dead_devices
01-11 11:08:39.347 3160-3160/? I/floodinfo: usb_discover libusb_free_device_list
01-11 11:08:39.347 3160-3160/? I/floodinfo: usb_discover ************pairFailed! StopProxy**********
01-11 11:08:39.347 3160-3160/? I/floodinfo: usb_discover valid_count is 0
01-11 11:08:39.347 3160-3160/? I/floodinfo: usb_process usb_discover return 0
01-11 11:08:39.347 3160-3160/? I/floodinfo: usb_process return 0
01-11 11:08:39.347 3160-3160/? I/floodinfo: main_loop iteration
01-11 11:08:39.347 3160-3160/? I/floodinfo: USB timeout is 1000 ms
01-11 11:08:39.347 3160-3160/? I/floodinfo: Device timeout is 1000 ms
我在网上浏览了也发现类似现象。
请问有遇到这种情况吗?有什么好的解决方法没有?
jimmychan
Kernel 3.0.35 is an old BSP. I would suggest you to use a newer BSP.
