As title say, I'm searching all day but can't find any sample code of J1939 on S32K144.
If anyone know,I'm so glad if you inform me.(´Д`;)Thank you.
NXP does not provide J1939 library. It is necessary to ask SW companies like Vector, Simma Software and maybe some others:
http://www.vector.com/vi_canbedded_j1939_en.html
Supported devices from NXP can be found in this document:
https://vector.com/portal/medien/cmc/datasheets/CANbedded_Availability_EN.pdf
http://www.simmasoftware.com/j1939.html
Supported devices can be found on the same web page in tab “J1939 Ports”.
BR, Petr
