CCCSClient::ResetToDebug: Network timeout
lpineau
We are using USB TAP (900-75116; REV A; 01001362) to debug (via CodeWarrior) and to program (via 56800E Flash programmer) our target DSP 56F8355. CodeWarrior IDE version is 5.9.0 (build 4713) on Windows XP.
Unfortunately, I no longer can program or debug our target:
  • The "TX/RX" led on the USB TAP blinks and the "RUN/PAUSE" led remains RED,
  • An error "CCCSClient::ResetToDebug: Network timeout" is always displayed by Flash Programmer (please find enclosed its log file).
Could you please help to fix this issue.
Thanks in advance for your help.
ingostar
I guess you didn't get any help with this problem. I'm having the same problem with a device that has run smoothly for the last 10 years.
caesar_song
Could you please help to fix this issue. I have meet the issue,
