mpc5748g PE component compile issue(bool type conflict)
Question asked by yi huang on Jan 4, 2018
Latest reply on Jan 15, 2018 by yi huang
Hello,Community!
I've import a example project "frreertos_mpc5748g" , then I add a PE Component "flexcan" to the project. After generate PE code, I tried to build the project and here comes the errors ,like this :
I found that once the file contains the bool type parameters , the error happened. How to fix this issue?
Thanks a lot!
