Thanks for your reply.
I need a particular features of 4.14, then I need 4.14+ only.
Compulab don't have time to fix this issue.
Cheers,
please read support policy on
FSL Community BSP Release Notes 2.2 documentation
every new board must have someone assigned as maintainer. This ensures, in long term, all boards with a maintainer assigned. Current orphan boards are not going to be removed unless it causes maintenance problem and the fix is not straightforward.
When a build error is detected, the maintainer will “fix” it.
alternatively you can apply to
Hi Herman
Linux 4.14 is not supported linux version by nxp, please try for example L4.1.15
described on
Issues with Linux 4.14 can be posted on compulab forum or meta-fsl-arm mailing list,
so that someone familiar with it could try to assist you.
https://lists.yoctoproject.org/listinfo/meta-freescale
