Application bin files in kw40z in MAC software
aldaxhafa
Hello everyone,
I am currently working with the frdmkw40z. I want to use 802.15.4 standard for my project. I am trying to understand the application examples provided by nxp to adapt it in my application. What I wanted to know is if there is any place where I can get the code of the bin file found in  KW40Z_Connectivity_Software_1.0.1\ConnSw\tools\binaries.
Thank you in advance,
Alda
Labels (2)
ovidiu_usturoi
Hi Alda,
You can find the source code/projects files in the corresponding folder of the board.
For example:
smac_connectivity_test_frdmkw41z.bin -> the source code/project is located in: ...\MKW41Z_ConnSw_1.0.2\boards\frdmkw41z\wireless_examples\smac\connectivity_test\.
Ovidiu
aldaxhafa
Hi Ovidiu,
Thank you for the reply. What I really meant was that there is a folder with binary files (See the Picture below) which don't have its corresponding source codes. Do you have any idea where can this codes be found.
Best,
estephania_mart
You can find those source codes in the examples board folder:
C:\Freescale\KW40Z_Connectivity_Software_1.0.1\ConnSw\examples
In those folders, you can find the different examples available, in the Bluetooth, you will find available a set of examples which are even more than the ones in the binary files.
Estephania
