Image of JPEG format of ov2710 Camera not saving in Android 6 in IMx6board
ayyappadasps
Hi ,
     If i am trying to save the captured image from ov2710 using a application  in Android 6 ,image is  saving,but no size and only white color is coming in saved image ...Please help me??
Labels (4)
weidong_sun
Hello Ayyappadas,
   See below, please!
(1) OV2710 outputs 10bit RAW RGB data.
According to OV2710 datasheet, it only supports 10bit RAW RGB data, not support JPEG stream.
(2) I.MX6/7 serials Processor
There is no ISP module in I.MX6/7 processor, so it requires camera should have ISP function.
If you use a camera with RAW data output, mxc_v4l2_caputre driver can normally receive data, but it doesn't do subsequent processing.
(3) RAW data to YUV
Actually , you can do data conversion from RAW to YUV data after capturing image in software, but we don't have ready-made source code for it, you will have to do it by yourself.
Have a nice day!
TIC Weidong Sun
weidong_sun
Hello Ayyappadas,
   See below, please!
(3) RAW data to YUV
Have a nice day!
TIC Weidong Sun
ayyappadasps
Thankyou  Weidong Sun . I will follow your Method
