Kinetis tool for memory read
vigneshbalaji
Senior Contributor I
    Is there any windows tool to read memory of kinetis controller continuously?
kerryzhou
Hi VIGNESH BALAJI,
Thank you for your interest in NXP kinetis product, I would like to provide service for you.
If you want to read the KEA128 memory, you can use the IDE enter the debug mode, then read it in the memory window.
Another way, don't need to use the IDE, you can use the JLINK debugger, then associate with the JLINK Command, after you connect the KEA chip,
input the command: memory address, length
Then the JLINK commander will show the memory data.
Wish it helps you!
If you still have question about it, please kindly let me know!
Kerry
