S32K144 problems with LPSPI master transfer using edma, edma not callback
asdfq
Hello.
I configure lpspi master using edma, master recv can finish normally, but send edma not work right.  Spi slave using edma work fine. Then I configure s32k144_LPSPI_Example master using edma, it didn't work either.
Please help.
kind regards.
danielmartynek
Sorry for the late response,
Could you attach the example that you modified?
