Hello,I used the LPCScrypt for lpc4330, but it can not work.
It has booted successfully,but says no serial port,actually the com port is already exist.
Attachment is the screen shot.
Please help for the problem why it can not find the serial port.
Hi John Wang,
I'd highly recommend you to use the most updated LPCScrypt instead the version you use, then give a try again.
TIC
