MPC8323
MPC8323
xuqinlei521
I use"Freescale CodeWarrior"software to write a program in MPC8323, but the program crashes, cannot start, then write with the computer of colleague no problem. Is my software installed have a problem, or is there a problem on the setting
alexander_yakov
Please enable "Verify Memory Writes" checkbox on "Target Configuration" window and check is tere are any errors reported on writing.
Alexander
TIC
xuqinlei521
I'm very sorry, I just saw your reply. First of all, thank you for your reply. It is very helpful for me. I am just an ordinary Chinese skilled worker, not familiar with the software, the problem is not solved, the computer burning program is still dead. I see that the settings are normal. Only a fram.h file is missing in the MCP engineering file. I don't know what the file affects, and you have to ask for it. Thank you very much.
Lei Xu
XULEI
