breakpoint installation failed: unmatched quote
donliao
I cannot use the breakpoint in S32DS V1.1 and S32DS V1.2, when I set the breakpoint that will be an error message "breakpoint installation failed: unmatched quote".Please help me to solve it, thanks!
martin_kovar
could you please specify, which microcontroller you use and also, what program you have download into the memory?
Martin
donliao
Hi Martin:
I used the S32R274 and downloaded AIPS_cfg(), XBAR_cfg(), PRAMC_cfg(), XOSC_cfg(), PLL0_cfg(), PLL1_cfg(), SDPLL_cfg(), CGM_cfg(), xcptn_xmpl(), etc., thanks!
B.R.
Don
martin_kovar
Hello Don,
thanks for information, but I need your project (or at least some test projects which demonstrates your issue) to check it on my side.
Also, which debug probe you use?
Martin
donliao
Hi Martin:
Any projects, for example the S32R274-ModeTransition-S32DS.zip, such as attachment files.
I used the CYCLONE of PEmicro.
Thanks!
B.R.
Don
