I have an iMX6UL board,
i am doing U-Boot PWM Test for Changing the brightness on LCD Display,
is there any command to perform the test in U-Boot .
Thank you :smileyhappy:
Hi Anshul
usually pwm is used in uboot for lcd brightness, seems
one can add special pwm commands using pwm driver in
drivers/pwm/pwm-imx.c. Pwm examples can be found in Github SDK
https://github.com/backenklee/swp-report/tree/master/iMX6_Platform_SDK
Hi igor,
Thanks for Your Reply,
i am not getting which special command i need to enable in driver,
can u please help me on this.
Anshul
