Cortex A7 & M4 communication
suryapradhan
I am using IMX7D & trying to  communicate between cortex -A7 & M4.
Currently i am able to communicate between the processors using RPMSG.
But we have to load the firmware/application to M4 in bootloader prompt using fatload, bootaux commands.
Is there any way we can reset & load the firmware from linux kernel.
Surya
Labels (2)
gary_bisson
Senior Contributor III
I suggest you have a look at this tool from NXP:
GitHub - codeauroraforum/imx-m4fwloader: Tool for loading firmware to M4 core on i.MX6SX and 7D
Gary
suryapradhan
HI Gary Bisson,
Thanks for the reply.
I am using "m4fwloader" tool to load,start & stop the firmware to Cortex-M4 from linux- cortex A7.
But i got one issue here, while stopping the firmware & starting again.
Scenario:
I am using "rpmsg_str_echo_freertos_example.bin" firmware & able to communicate with M4 properly.
Next i  stopped it & started it again using "m4fwloader stop" & "m4fwloader start" command.
Now if i do  "echo hi > /dev/ttyRPMSG", i am getting all my previous messages[message from last communication] along with new message.
Any suggestion on this.
Surya
