FRDM kl82z board: after copying Jlink bin file to bootloader mode, unable to load a project demo
tilakmarupilla
Having used Keil v5 for FRDM KL82Z board, and facing a error of 'NO VALID CPU DEFINED' for a quick sample project loaded from 'Kinetis SDK project generator', I switched to Kinetis design studio and followed the guidance given here exactly
But even on following all the steps correctly, I got stuck up at step 3 'Build,Run' video.
where on copying Jlink bin file to Bootloader mode(Reset button pressed and then loaded the board to PC) and launching the project, which I previously generated from 'Kinetis SDK project generator', it fails to launch the project and says it is unable to recognise my device.
Kinldy anyone help me.
Tags (2)
Hello Tilak Marupilla,
1. Please take a screenshot about your Device Manager of your PC, also the KDS debugger configuraiton.
2. Please take a video or pictures to show your steps.
3. There is a KDS user guide under KDS install path: KDS_v3\doc\KDS_Users_Guide.pdf.
I help you porting this question to KDS thread .
Hope it helps
Alice
Hope it helps
Alice
