ls2088a uboot not detecting SATA drive
Question asked by David Hill on Dec 15, 2017
Latest reply on Dec 18, 2017 by David Hill
Using both:
  http://www.nxp.com/lgfiles/sdk/lsdk1709/firmware_ls2088ardb_uboot_norboot.img
and the img created with flex-builder
  U-Boot 2016.092.0+ga06b209 (Mar 30 2017 - 01:15:01 +0800)
U-boot is not detecting my SATA drives.
Using: scsi reset
and no drives are found.
I have tried several different drives, cables and SATA ports with the same results.
Given the uboot will be polling the drives to figure which to boot, I am not going to be getting very far.
Interestingly, when the flash image of Linux is run, I see the drive is often detected but is disabled shortly after.
Any suggestions on what to try next ?
