how to modify wct-5wtxauto  for 1-coil system
Question asked by Devin Park on Dec 15, 2017
Latest reply on Dec 19, 2017 by Jose Alberto Reyes Morales
WCT-5WTXAUTO is a 5w 3-coil tx charger. BTW, I want to make a 1-coil tx charger
On the side of HW, some unnecessary blocks would be able to be removed : coil selection-related TR, etc...
Then how about SW-side? I'm using SDK4.0. I found some coil-related variables.
      #define NUM_COILS_PER_DEVICE                    1u//3u
And then, I modified following ARRAY variables which controlled 3 coils originally.
   BYTE byCoilIds[NUM_DEVICES][NUM_COILS_PER_DEVICE] = {{ 0u } }; //{2,1,0};         // set coil combinations by customer
   #define PWM_CHANNEL_MAPPING                     { 3u }//{ 3u, 3u, 3u }
   #define COIL_ENABLE_CONTROL_PORTS               { (STANDARD_REGISTER_SIZE *) &GPIOC_DR, }
   #define COIL_ENABLE_CONTROL_BIT_MASKS           { 0x2000u}
   #define COIL_DISCHARGE_CONTROL_PORTS            { (STANDARD_REGISTER_SIZE *) &GPIOB_DR }
   #define COIL_DISCHARGE_CONTROL_BIT_MASKS        { 0x80u}
And also  EEdata_FlashDefaults.asm was modified to have only 1 coil parameters..
I wonder if it's enough for 1-coil migration. .
Pls help me if you have any experience on it.
Thanks & BR,
Devin
