Hi community,
I am working on imx7d sabresd board with Linux_4.9.11 and I am newbie to HDMI. I want to use HDMI transceiver ADV7513 instead of SiI9022. I have two driver for adv7513 which is using v4l2 and drm framework. But in default bsp we are not using any framework(may be I am wrong). So how can I integrate driver for adv7513 ? Which framework should I used ?
I found that we have also drm driver for SiI902 chip but we are not using it.
Thanks & regards.
Solanki Deven
Hi Deven
one can try to port new driver using
ADV7511 HDMI transmitter Linux Driver [Analog Devices Wiki]
and description of nxp hdmi driver in attached Linux Manual Chapter 15
