In my project I intend to boot a VxWorks image from NOR flash with the LS1043/LS1046 processors, initially from the LS1043ARDB and LS1046ARDB boards.
I would like to know what is the process for doing that? Do I need to prepend a special header to the image for the U-Boot to work properly, or do I just need to flash my VxWorks binary image to a certain address in flash as is?
Is there a document describing how to use U-Boot for booting an image from NOR?
Thanks in advance,
Yaron
P.S.
My guess is the fact that it's a VxWorks image doesn't really matter it could be any binary image compiled for ARMv8.
Please address your questions to the Wind River - normally such information is provided by the OS vendor.
Ok let me rephrase the question then.
When booting any image from NOR by U-boot (not necessarily vxworks) does U-boor require. that I prepend the image with any information for it to be able to boot the image?n
Please note that U-Boot is not an NXP product - its home (where you could pose your questions) is here:
