Synchronous Dual Die NAND Flash DQS on i.MX6
Question asked by arnemaathuis on Dec 11, 2017
Latest reply on Dec 12, 2017 by arnemaathuis
I want to use a Micron Dual Die NAND Flash(MT29F64G08AEC) in synchronous mode on an DualLite i.MX6.
For both DQS lines i can't seem to find any info on how to connect these to NANDF_DQS(SD4_DAT0.alt2 on i.MX6)
Can i simply gang both DQS pin on the memory device(which i also did with the DQ-x Datalines and control logic interface ,except Chip Select)
