MCUExpresso 10.1, Config Tools, Interrupts, Timers
luishs
Senior Contributor I
Hi.
Is there any option in MCUExpresso 10.1 Config Tools to configure the Interrupts ?. I do not see any option in the port configuration to configure interrupts. I would also like to select and configure the Timers in SDK components and I can not find them.
I come from working with the STM32 and Cubemx, and the truth is that in MCUExpresso Config Tools, many options are missing to configure the peripherals in an assisted way.
Hello Luis,
The MCUXpresso Config Tools includes peripheral tools , which can configure peripherals to
generates initialization code ,also can configure the interrupt.
About how to use it ,please have a look
at “MCUXpresso_IDE_User_Guide.pdf ”->11. MCUXpresso Config Tools
and  "MCUXpresso_IDE_ConfigTools_User_Manual.pdf" .
Which chip do you used ? Now the peripheral tool just support parts of our product :
https://community.nxp.com/docs/DOC-333073
The other chips will be added next release version.
Hope it helps
Alice
luishs
Hello Alice.
Thanks for your reply, but I do not locate the peripheral tools screen that you show. Also I have read the user manual and I do not know yet how to select it.
When I choose a peripheral, I only see the Routed pins, with no option to select to configure the peripheral.  May you tell me exactly how access to your screen to configure peripheral ?.
This is my screen with peripherals.
luishs
I have found the solution, open the Peripheral perspective. I works with MK64 LQFP100 and MK66 LQFP144.
