I have the frdm-k64f microcontroller when connected with power the rgb led doesnt glow when tilted or lifted ?
balajiv
pls reply soon.
kerryzhou
Hi BALAJI V,
  Did you program your FRDM-K64 board before?
  If yes, please check these information at first:
1. After you power on the FRDM-K64 board, can you find the FRDM-K64F device?
  If yes, please send my attached bubble.bin to your FRDM-K64FJ device.
  If No, please go to item 2.
2. Change your board debugger to JLINK.
  1) power off the board, then press the reset button and hold on it, plug the usb cable to your board J26 interface, you will find you board is a device named as : BOOTLOADER
    Then release the reset button
  2) Send my attached 02_OpenSDA_FRDM-K64F.bin to your BOOTLOADER device.
     After then send is finished, then unplug the board, plug it again, you will find your board is a device named as FRDM-K64FJ , then send bubble.bin to your FRDM-K64FJ device.
    Now, title the board, you will find the LED is blinking.
Please try it on your side.
If you still have question about it, please kindly let me know!
Kerry
