hid_param.HID_EpIn_Hdlr not called
Question asked by John Koning on Dec 7, 2017
Latest reply on Dec 8, 2017 by John Koning
I've implemented the core functions of the LPC11u24. Device enumerates correct, however transmitting reports is a problem.
As far as I understand the EP handler registered with "hid_param.HID_EpIn_Hdlr" should be triggered, each time the host
polls the device. This isn't the case now. If I call USBD_API->hw->WriteEP from within the main, the handler will be called, what I didn't expect.
So is the scenario:
host polls -> trigger EP handler -> write to endpoint
or
write to end point -> trigger EP handler
In case of the first, what goes wrong.
