i.MX7D clock source and power up sequence issue
felixhsu
Hi All
The customer use i.MX7D platform have two issue,
1. the clock source will start before  VDD_SNVS_IN, this situation have any concern?
2. the i.MX7D with PMIC PF3000, when first time power up have twice trigger PMIC_ON_REQ and NVCC_SD1, this situation is normal or not? how to explanation this phenomenon?
As below is scope measurement result.
Thanks.
Labels (5)
Hi Felix
no external voltages/signals should be applied to processor before completion power-up sequence.
please check power-up sequence and sect.2. i.MX7DS design checklist
Hardware Development Guide for i.MX7Dual and 7Solo Applications Processors
http://www.nxp.com/files/32bit/doc/user_guide/IMX7DSHDG.pdf
felixhsu
Hi Igor
1. so external clock should be same time with  VDD_SNVS_IN, right?
2. the Hardware Development Guide which part have explanation twice trigger PMIC_ON_REQ and NVCC_SD1?
Hi Felix
no.
No external voltages/signals should be applied to processor before completion power-up sequence.
felixhsu
Hi Igor
About question 2, do you have any comments?
I can not found related explanation in the document.
Thanks.
Hi Felix
for question 2 unfortunately I am not aware of documents describing in details.
Suggest follow Hardware Guide.
