GPU Profiling with Vivante VDK Tools Version 2.0
Question asked by Ahmed Al-Zanam on Dec 6, 2017
Latest reply on Aug 27, 2019 by Gabriel Sandu
i have already read this article. but i need more information about GPU Profiling using Vivante Tools. I'm using i.MX6Solo to make UI with Qt Framework. I need to profile the GPU to know how works it with my UI.
I have setup the u-boot and system envs as below:
U-Boot:
galcore.gpuProfiler=1
galcore.showArgs=1
User-space:
USE_PROFILER=1
VIV_PROFILE=3
VP_FRAME_END=1024
VP_FRAME_NUM=1023
VP_FRAME_START=0
VP_OUTPUT=foo.vpd
VP_SYNC_MODE=0
cat /sys/module/galcore/parameters/gpuProfiler is always 0 but i use echo 1 > /sys/module/galcore/parameters/gpuProfiler
after UI starts the tool makes foo.vpd but it is 0 Bytes. Nothing is inside.
Do i miss something?
thank you for reply.
Zanam
