Busybox Applet: how to add and remove
Question asked by David XY Zhou on Dec 6, 2017
The busybox has a defconfig file. I add/remove items such as
CONFIG_IPCALC=y
#CONFIG_IP is not set
to
#CONFIG_IPCALC is not set
CONFIG_IP=y
But they are not add / remove into installed yocto /bin folder.
type the ip command under busybox $ ip
ip: command not found
I also used
bitbake - c menuconfig busybox
save the changes, and re-bitbake busybox
There is nothing changed in the installed image.
What's wrong?
Thank you,
David Zhou
