Hello all,
I'm using MPC5602P on CW2.9 platform. I wanted to know what will happen if I flash the unused bytes with 0x00 instead of 0xFF. The reason why I'm asking is, after my bin2hex conversion all my unused bytes are filled with 0x00 but not 0xFF. Also I don't want to use direct mot or hex file. Kindly help.
Thanks in advance,
BJ Rajendranath
Solved! Go to Solution.
Nothing happens. You can still flash with 0x00 and the code will work as expected.
