I use IMX6DL, Kernel3.14.52, Uboot2015.04. Now I'm porting one LCD which is LVDS port. Follow is its timing.
My device tree config is follow:
I also check waveform from scope , clock is 39.9MHz
The attach is my LVDS LCD display.
Anyone can help me solve this problem ?
Hi leavs
one can change fsl,data-width = <18>; and select appropriate kernel boot parameter
using Table 11. Common kernel boot parameters attached Release Notes,
try with nxp bsps described on
http://www.nxp.com/products/software-and-tools/software-development-tools/i.mx-software-and-tools/i.mx-6series-i.mx-7series-software-and-development-tool-resources:IMX_SW
