RCW override has no effect
gregbuchannan
I'm debugging a new T2080 board.  Using RCW override to initialize the T2080.  A dump of the RCW status registers fully matches the RCW override data provided.  However, individual status register (such as MEM_PLL_RAT, the DDR PLL ratio) are still showing the default RCW values (seem to match the hard-coded values).
Any idead why the RCW would not be taking hold?
ufedor
Preliminary response from the CW support:
"from ccs point of view overriding the pll is not supported"
