Android for iMX7D Pico
liranbh
Im looking for Android sources for IMX7D Pico , I found Android Things but i need regular Android (preferred version 6 or later).
Can someone point me to the source?
thanks
gusarambula
Hello liran Bh,
The i.MX7D Pico board was designed with Android Things in mind and it’s BSP is Android Things-based. There is no support on the i.MX Android BSP for this board so you would need to port it if you intend to use a regular Android distribution on the i.MX7D Pico board.
My apologies for the inconvenience,
