Android Nougat - crash on imx6qp
manjunathjoshi
Contributor V
Hello All,
I am customizing a board with MX6QP processor. Android comes up but crashes every time. Below are the logs. Please let me know if anyone has a fix.
Booting Linux on physical CPU 0x0
Linux version 4.9.17-svn30 (m2and@m2and) (gcc version 4.9 20150123 (prerelease) (GCC) ) #2 SMP PREEMPT Wed Dec 6 12:44:12 IST 2017
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
OF: fdt:Machine model: i.MX6 Quad plus SMARC Device Board
cma: Reserved 448 MiB at 0x1a000000
Memory policy: Data cache writealloc
On node 0 totalpages: 262144
free_area_init_node: node 0, pgdat c11edac0, node_mem_map c9800000
  Normal zone: 1232 pages used for memmap
  Normal zone: 0 pages reserved
  Normal zone: 157696 pages, LIFO batch:31
  HighMem zone: 104448 pages, LIFO batch:31
percpu: Embedded 15 pages/cpu @e66b8000 s31040 r8192 d22208 u61440
pcpu-alloc: s31040 r8192 d22208 u61440 alloc=15*4096
pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260912
Kernel command line: console=ttymxc0,115200 init=/init video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24 bpp=32 fbmem=10M fb0base=0x27b00000 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off vmalloc=400M androidboot.console=ttymxc0 androidboot.storage_type=sd consoleblank=0 androidboot.hardware=freescale cma=448M androidboot.selinux=permissive androidboot.dm_verity=disabled no_console_suspend androidboot.serialno=0f1421d4e3167aba androidboot.storage_type=emmc
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 559924K/1048576K available (11264K kernel code, 988K rwdata, 3652K rodata, 1024K init, 585K bss, 29900K reserved, 458752K cma-reserved, 417792K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xe7000000 - 0xff800000   ( 392 MB)
    lowmem  : 0xc0000000 - 0xe6800000   ( 616 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc0c00000   (12256 kB)
      .init : 0xc1000000 - 0xc1100000   (1024 kB)
      .data : 0xc1100000 - 0xc11f7040   ( 989 kB)
       .bss : 0xc11f7040 - 0xc12894b0   ( 586 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
        Build-time adjustment of leaf fanout to 32.
NR_IRQS:16 nr_irqs:16 16
L2C-310 erratum 769419 enabled
L2C-310 enabliinit: write_file: Unable to write to '/config/usb_gadget/g1/UDC': No such device
ng early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 16 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 16 ways, 1024 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76470001
Switching to timer-based delay loop, resolution 333ns
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 63708681559acc_open
5 ns
Console: colour dummy devicacc_release
e 80x30
Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
Security Framework initialized
SELinux:  Initializing.
SELinux:  Starting in permissive mode
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
CPU0: update cpu_capacity 1024
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x10100000 - 0x10100058
CPU1: update cpu_capacity 1024
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
CPU2: update cpu_capacity 1024
CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
CPU3: update cpu_capacity 1024
CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Brought up 4 CPUs
SMP: Total of 4 processors activated (24.00 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
CPU3: update max cpu_capacity 1024
devtmpfs: initialized
CPU2: update max cpu_capacity 1024
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 1024 (order: 4, 65536 bytes)
pinctrl core: initialized pinctrl subsystem
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor menu
CPU identified as i.MX6QP, silicon rev 1.0
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6q-pinctrl 20e0000.iomuxc: Invalid fsl,pins property in node /soc/aips-bus@02000000/iomuxc@020e0000/imx6qdl-sabresd/pwm1grp
imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
imx-gpc 20dc000.gpc: Registered imx-gpc
mxs-dma 110000.dma-apbh: initialized
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
2000000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
2000000.aips-bus:usbphy_nop2 supply vcc not found, using dummy regulator
i2c i2c-0: IMX I2C adapter registered
i2c i2c-0: can't use DMA, using PIO instead.
i2c i2c-1: IMX I2C adapter registered
i2c i2c-1: can't use DMA, using PIO instead.
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 driver probed
mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 dphy version is 0x3130302a
MIPI CSI2 driver module loaded
imx rpmsg driver is registered.
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource mxc_timer1
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 1592K (c5000000 - c518e000)
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
Bus freq driver module loaded
audit: initializing netlink subsys (disabled)
audit: type=2000 audit(0.730:1): initialized
workingset: timestamp_bits=30 max_order=18 bucket_order=0
ntfs: driver 2.1.32 [Flags: R/W DEBUG].
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.26)
SELinux:  Registering netfilter hooks
bounce: pool size: 64 pages
io scheduler noop registered
imx-weim 21b8000.weim: Driver registered.
backlight supply power not found, using dummy regulator
mxc_mipi_dsi 21e0000.mipi: invalid reset gpio: -2
mxc_mipi_dsi 21e0000.mipi: failed to reset: -2
mxc_mipi_dsi: probe of 21e0000.mipi failed with error -2
20e0000.hdmi_video supply HDMI not found, using dummy regulator
mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0xa:0xa0:0xc1
fbcvt: 1920x1080@60: CVT Name - 2.073M9
mxc_sdc_fb fb@0: registered mxc display driver hdmi
imx-ipuv3 2400000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
Console: switching to colour frame buffer device 240x67
mxc_sdc_fb fb@1: Can't get fb option for mxcfb1!
mxc_sdc_fb fb@2: Can't get fb option for mxcfb2!
mxc_sdc_fb fb@3: Can't get fb option for mxcfb3!
imx-sdma 20ec000.sdma: no iram assigned, using external mem
imx-sdma 20ec000.sdma: loaded firmware 3.3
pfuze100-regulator 0-0008: Full layer: 2, Metal layer: 1
pfuze100-regulator 0-0Generic PHY 2188000.ethernet:05: attached PHY driver [Generic PHY] (mii_bus:phy_addr=2188000.ethernet:05, irq=-1)
008: FAB: 0, FIN: 0
pfuze100-regulator 0-0008: pfuze100 found.
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 29, base_baud = 5000000) is a IMX
mxc_hdmi 20e0000.hdmi_video: create default modelist
console [ttymxc0] enabled
21e8000.seriaIPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
l: ttymxc1 at MMIO 0x21e8000 (irq = 76, base_baud = 5000000) is a IMX
21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 77, base_baud = 5000000) is a IMX
imx sema4 driver is registered.
[drm] Initialized
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
zram: Added device: zram0
at24 0-0057: 4096 byte 24c32 EEPROM, writable, 32 bytes/write
ahci-imx 2200000.sata: fsl,transmit-level-mV not specified, using 00000024
ahci-imx 2200000.sata: fsl,transmit-boost-mdB not specified, using 00000480
ahci-imx 2200000.sata: fsl,transmit-atten-16ths not specified, using 00002000
ahci-imx 2200000.sata: fsl,receive-eq-mdB not specified, using 05000000
ahci-imx 2200000.sata: SSS flag set, parallel bus scan disabled
ahci-imx 2200000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci-imx 2200000.sata: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
scsi host0: ahci-imx
ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 84
spi_imx 2008000.ecspi: probed
spi_imx 2014000.ecspi: probed
libphy: Fixed MDIO Bus: probed
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
CAN device driver interface
2188000.ethernet supply phy not found, using dummy regulator
pps pps0: new PPS source ptp0
fec 2188000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
fec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: 7e:6f:c2:83:fc:ce
libphy: fec_enet_mii_bus: probed
fec 2188000.ethernet eth0: registered PHC device 0
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
usbcore: registered new interface driver kaweth
pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
usbcore: registered new interface driver pegasus
usbcore: registered new interface driver rtl8150
usbcore: registered new interface driver r8152
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver cdc_eem
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
ehci-mxc: Freescale On-Chip EHCI Host driver
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver ftdi_sio
usbserial: USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver option
usbserial: USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver usbtest
usbcore: registered new interface driver usb_ehset_test
2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 4.9.17-svn30 ehci_hcd
usb usb1: SerialNumber: ci_hdrc.1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
usbcore: registered new interface driver xpad
usbcore: registered new interface driver usb_acecad
usbcore: registered new interface driver aiptek
usbcore: registered new interface driver gtco
usbcore: registered new interface driver hanwang
usbcore: registered new interface driver kbtab
snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc0
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x/sz) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR SANYO protocol handler initialized
IR Sharp protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR XMP protocol handler initialized
mxc_v4l2_output v4l2_out: V4L2 device registered as video16
mxc_v4l2_output v4l2_out: V4L2 device registered as video17
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
max8903-charger max8903@0: Not setting offset-charger in dts!
max8903-charger max8903@0: Not setting offset-discharger in dts!
max8903-charger max8903@0: Not setting offset-usb-charger in dts!
max8903-charger max8903@0: request max8903-FLT error!!
max8903-charger: probe of max8903@0 failed with error -16
imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
mxc_vpu 2040000.vpu_fsl: VPU initialized
mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
mxc_hdmi_cec soc:hdmi_cec@00120000: HDMI CEC initialized
Galcore version 6.2.2.96445
ata1: SATA link down (SStatus 0 SControl 300)
ahci-imx 2200000.sata: no device found, disabling link.
ahci-imx 2200000.sata: pass ahci_imx..hotplug=1 to enable hotplug
mmc2: new DDR MMC card at address 0001
mmcblk2: mmc2:0001 SEM04G 3.69 GiB
mmcblk2boot0: mmc2:0001 SEM04G partition 1 2.00 MiB
mmcblk2boot1: mmc2:0001 SEM04G partition 2 2.00 MiB
mmcblk2rpmb: mmc2:0001 SEM04G partition 3 2.00 MiB
 mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
random: fast init done
caam 2100000.caam: ERA source: CAAMVID.
caam 2100000.caam: AXI pipeline throttling enabled.
caam 2100000.caam: Instantiated RNG4 SH1
caam 2100000.caam: device ID = 0x0a16010000000000 (Era 4)
caam 2100000.caam: job rings = 2, qi = 0
caam algorithms registered in /proc/crypto
caam_jr 2101000.jr0: registering rng-caam
platform caam_sm: blkkey_ex: 4 keystore units available
platform caam_sm: 64-bit clear key:
platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
platform caam_sm: 64-bit black key:
platform caam_sm: [0000] b6 12 8f db b7 dd 4d b8
platform caam_sm: [0008] 0a f9 5f c8 b3 f2 86 79
platform caam_sm: 128-bit clear key:
platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
platform caam_sm: 128-bit black key:
platform caam_sm: [0000] c4 3b b7 31 75 96 22 4e
platform caam_sm: [0008] 1a 90 14 b0 3c 3d 6e 2e
platform caam_sm: 192-bit clear key:
platform caam_sm: [0016] 10 11 12 13 14 15 16 17
platform caam_sm: 192-bit black key:
platform caam_sm: [0000] 3e bb 8d 19 cd 8e 38 2a
platform caam_sm: [0008] 6a e0 04 fc 9b a5 7f dd
platform caam_sm: [0016] dd d8 9b b3 63 7c f9 0b
platform caam_sm: [0024] 70 2a 91 f7 53 3c 28 88
platform caam_sm: 256-bit clear key:
platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
platform caam_sm: 256-bit black key:
platform caam_sm: [0000] 18 4c a1 ee 56 4c 6e 11
platform caam_sm: [0008] 15 bc 1d a3 69 1f 63 c6
platform caam_sm: [0016] 2f 88 de 98 16 f5 27 50
platform caam_sm: [0024] ab 19 9a 25 23 7c 06 2d
platform caam_sm: 64-bit unwritten blob:
platform caam_sm: [0000] 00 00 00 00 00 00 00 00
platform caam_sm: [0008] 00 00 00 00 00 00 00 00
platform caam_sm: [0016] 00 00 00 00 00 00 00 00
platform caam_sm: [0024] 00 00 00 00 00 00 00 00
platform caam_sm: [0032] 00 00 00 00 00 00 00 00
platform caam_sm: [0040] 00 00 00 00 00 00 00 00
platform caam_sm: [0048] 00 00 00 00 00 00 00 00
platform caam_sm: [0056] 00 00 00 00 00 00 00 00
platform caam_sm: [0064] 00 00 00 00 00 00 00 00
platform caam_sm: [0072] 00 00 00 00 00 00 00 00
platform caam_sm: [0080] 00 00 00 00 00 00 00 00
platform caam_sm: [0088] 00 00 00 00 00 00 00 00
platform caam_sm: 128-bit unwritten blob:
platform caam_sm: 196-bit unwritten blob:
platform caam_sm: 256-bit unwritten blob:
platform caam_sm: 64-bit black key in blob:
platform caam_sm: [0000] cc e8 3f e6 88 e2 2d c6
platform caam_sm: [0008] ea a0 aa 5a fc 89 49 f5
platform caam_sm: [0016] 5e 5c 76 7d eb 7e e2 70
platform caam_sm: [0024] 1d 5f 5f f6 bd 49 f7 cf
platform caam_sm: [0032] db 9f d2 97 c6 3d 31 4b
platform caam_sm: [0040] 8f 58 3c 53 ee 99 76 bb
platform caam_sm: [0048] 55 cf 32 7d 70 37 fa 70
platform caam_sm: 128-bit black key in blob:
platform caam_sm: [0000] 72 d6 3d cb 5c cb 16 d8
platform caam_sm: [0008] da f8 62 8d 36 b6 d2 12
platform caam_sm: [0016] 0f 50 87 c0 1d 3b 58 19
platform caam_sm: [0024] d9 53 df 8a b6 0f 6c 12
platform caam_sm: [0032] f3 c8 30 e2 9d c6 59 8c
platform caam_sm: [0040] 98 bc a2 11 76 46 c6 cc
platform caam_sm: [0048] 28 65 74 02 92 e9 3e 88
platform caam_sm: [0056] a7 fc c6 d4 50 db 9d 90
platform caam_sm: 192-bit black key in blob:
platform caam_sm: [0000] f4 37 ef 89 d7 ef 66 d3
platform caam_sm: [0008] a3 6d 48 1e 4b 0d e9 d2
platform caam_sm: [0016] 96 84 27 4c 91 56 39 d1
platform caam_sm: [0024] d1 8f a0 ff da cf a1 87
platform caam_sm: [0032] 32 0f f6 f1 03 fa 09 64
platform caam_sm: [0040] 8f a0 e7 5d 25 7f 20 0a
platform caam_sm: [0048] c3 5f 90 8c 9d 92 1c ab
platform caam_sm: [0056] 7c e1 eb 58 00 b5 61 88
platform caam_sm: [0064] ff 77 40 62 25 b6 da f1
platform caam_sm: 256-bit black key in blob:
platform caam_sm: [0000] 94 4a 9b 74 fa 68 c6 3f
platform caam_sm: [0008] f0 15 da 07 ac ea 32 8c
platform caam_sm: [0016] c5 06 a4 51 08 c9 01 29
platform caam_sm: [0024] e7 cd 75 22 68 bc d7 48
platform caam_sm: [0032] 84 fd 35 45 3f c4 4d 74
platform caam_sm: [0040] c6 8b 11 d2 aa 99 fa 98
platform caam_sm: [0048] 33 ec 5f 5b 29 55 2a d5
platform caam_sm: [0056] b4 be 38 21 8b 97 e0 08
platform caam_sm: [0064] af a7 2a 83 82 a3 0e 61
platform caam_sm: [0072] ad e7 4b 21 9e ca ed 8c
platform caam_sm: restored 64-bit black key:
platform caam_sm: [0000] e0 f8 35 d5 c5 f3 fa c2
platform caam_sm: [0008] ad a3 e9 c4 0a bc 82 5a
platform caam_sm: restored 128-bit black key:
platform caam_sm: restored 192-bit black key:
platform caam_sm: [0016] ea 77 0f 44 fd cb 54 e6
platform caam_sm: [0024] bd 9a 10 ab 46 13 55 3e
platform caam_sm: restored 256-bit black key:
snvs-secvio 20cc000.caam-snvs: can't get snvs clock
snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ashmem: initialized
usbcore: registered new interface driver snd-usb-audio
sgtl5000 1-000a: sgtl5000 revision 0x11
sgtl5000 1-000a: Using internal LDO instead of VDDD: check ER1
fsl-ssi-dai 202c000.ssi: No cache defaults, reading back from HW
imx-sgtl5000 sound: phandle missing or invalid
imx-sgtl5000: probe of sound failed with error -22
imx-audio-hdmi sound-hdmi: hdmi-hifi.0 <-> soc:hdmi_audio@00120000 mapping ok
NET: Registered protocol family 26
u32 classifier
    Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
ctnetlink v0.93: registering with nfnetlink.
xt_time: kernel timezone is -0000
ip_tables: (C) 2000-2006 Netfilter Core Team
arp_tables: arp_tables: (C) 2002 David S. Miller
Initializing XFRM netlink socket
NET: Registered protocol family 10
mip6: Mobile IPv6
ip6_tables: (C) 2000-2006 Netfilter Core Team
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
NET: Registered protocol family 15
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20161123 t)
can: netlink gateway (rev 20130117) max_hops=1
8021q: 802.1Q VLAN Support v1.8
cpu cpu0: Registered imx6q-cpufreq
registered taskstats version 1
imx_thermal 2000000.aips-bus:tempmon: Extended Commercial CPU temperature grade - max:105C critical:100C passive:95C
snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:35 UTC (35)
usb_otg_vbus: disabling
wm8962-supply: disabling
mipi_dsi_pwr_on: disabling
sensor-supply: disabling
SW4: disabling
SWBST: disabling
VGEN2: disabling
ALSA device list:
  #0: imx-hdmi-soc
Freeing unused kernel memory: 1024K (c1000000 - c1100000)
init: init first stage started!
SELinux: 2048 avtab hash slots, 6276 rules.
SELinux:  1 users, 2 roles, 639 types, 0 bools, 1 sens, 1024 cats
SELinux:  63 classes, 6276 rules
SELinux:  Permission validate_trans in class security not defined in policy.
SELinux:  Class cap_userns not defined in policy.
SELinux:  Class cap2_userns not defined in policy.
SELinux: the above unknown classes and permissions will be denied
SELinux:  Completing initialization.
SELinux:  Setting up existing superblocks.
audit: type=1403 audit(35.620:2): policy loaded auid=4294967295 ses=4294967295
init: (Initializing SELinux non-enforcing took 0.10s.)
init: init second stage started!
init: property_set("ro.boot.storage_type", "emmc") failed
init: Running restorecon...
init: waitpid failed: No child processes
init: (Loading properties from /default.prop took 0.00s.)
init: (Parsing /init.environ.rc took 0.00s.)
init: (Parsing /init.usb.rc took 0.00s.)
init: (Parsing init.freescale.usb.rc took 0.00s.)
init: (Parsing init.freescale.i.MX6QP.rc took 0.00s.)
init: (Parsing init.freescale.sd.rc took 0.00s.)
ueventd: ueventd started!
ueventd: Coldboot took 0.36s.
Console: switching to colour dummy device 80x30
watchdogd: started (interval 10, margin 20)!
audit: type=1400 audit(36.200:3): avc:  denied  { read write } for  pid=219 comm="slideshow" name="card0" dev="tmpfs" ino=7223 scontext=u:r:slideshow:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
audit: type=1400 audit(36.220:4): avc:  denied  { open } for  pid=219 comm="slideshow" path="/dev/dri/card0" dev="tmpfs" ino=7223 scontext=u:r:slideshow:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
audit: type=1400 audit(36.240:5): avc:  denied  { ioctl } for  pid=219 comm="slideshow" path="/dev/dri/card0" dev="tmpfs" ino=7223 ioctlcmd=0x640c scontext=u:r:slideshow:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
audit: type=1400 audit(36.260:6): avc:  denied  { dac_override } for  pid=219 comm="slideshow" capability=1  scontext=u:r:slideshow:s0 tcontext=u:r:slideshow:s0 tclass=capability permissive=1
init: Service 'exec 1 (/sbin/slideshow)' (pid 219) exited with status 0
EXT4-fs (mmcblk2p3): mounted filesystem with ordered data mode. Opts: barrier=1
fs_mgr: __mount(source=/dev/block/mmcblk2p3,target=/system,type=ext4)=0
EXT4-fs (mmcblk2p10): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk2p10): recovery complete
EXT4-fs (mmcblk2p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
fs_mgr: __mount(source=/dev/block/mmcblk2p10,target=/data,type=ext4)=0
EXT4-fs (mmcblk2p4): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk2p4): recovery complete
EXT4-fs (mmcblk2p4): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
fs_mgr: __mount(source=/dev/block/mmcblk2p4,target=/cache,type=ext4)=0
EXT4-fs (mmcblk2p5): mounted filesystem with ordered data mode. Opts: (null)
fs_mgr: __mount(source=/dev/block/mmcblk2p5,target=/device,type=ext4)=0
init: (Parsing /system/etc/init/atrace.rc took 0.00s.)
init: (Parsing /system/etc/init/audioserver.rc took 0.00s.)
init: (Parsing /system/etc/init/bootanim.rc took 0.00s.)
init: (Parsing /system/etc/init/bootstat.rc took 0.00s.)
init: (Parsing /system/etc/init/cameraserver.rc took 0.00s.)
file system registered
using random self ethernet address
using random host ethernet address
zram0: detected capacity change from 0 to 314572800
logd.auditd: start
logd.klogd: 35712800003
Adding 307196k swap on /dev/block/zram0.  Priority:-1 extents:1 across:307196k SS
binder: 253:253 transaction failed 29189, size 0-0
logd.daemon: reinit
healthd: No battery devices found
ERROR: v4l2 capture: slave not found!
capability: warning: `main' uses 32-bit capabilities (legacy support in use)
init: write_file: Unable to open '/sys/devices/system/cpu/cpufreq/interactive/timer_rate': No such file or directory
init: write_file: Unable to open '/sys/devices/system/cpu/cpufreq/interactive/min_sample_time': No such file or directory
init: write_file: Unable to open '/sys/devices/system/cpu/cpufreq/interactive/go_hispeed_load': No such file or directory
random: crng init done
init: write_file: Unable to open '/proc/sys/vm/extra_free_kbytes': No such file or directory
sm_m2and:/ # init: Service 'bootanim' (pid 328) exited with status 0
init: Starting service 'exec 4 (/system/bin/bootstat)'...
init: Service 'exec 4 (/system/bin/bootstat)' (pid 940) exited with status 0
init: Starting service 'exec 5 (/system/bin/bootstat)'...
init: Service 'exec 5 (/system/bin/bootstat)' (pid 949) exited with status 0
init: Starting service 'exec 6 (/system/bin/bootstat)'...
------------[ cut here ]------------
WARNING: CPU: 0 PID: 267 at kernel/sched/core.c:3346 cgroup_tryget+0x58/0xd0
DEBUG_LOCKS_WARN_ON(val > preempt_count())Modules linked in:
CPU: 0 PID: 267 Comm: mediacodec Not tainted 4.9.17-svn30 #2
Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
[<c0110e4c>] (unwind_backtrace) from [<c010ca80>] (show_stack+0x10/0x14)
[<c010ca80>] (show_stack) from [<c0bc11d0>] (dump_stack+0x80/0x94)
[<c0bc11d0>] (dump_stack) from [<c0134d84>] (__warn+0xec/0x104)
[<c0134d84>] (__warn) from [<c0134de4>] (warn_slowpath_fmt+0x48/0x6c)
[<c0134de4>] (warn_slowpath_fmt) from [<c01ce39c>] (cgroup_tryget+0x58/0xd0)
[<c01ce39c>] (cgroup_tryget) from [<c01d2d9c>] (cgroup_kn_lock_live+0x2c/0x80)
[<c01d2d9c>] (cgroup_kn_lock_live) from [<c01d40dc>] (__cgroup_procs_write+0x54/0x320)
[<c01d40dc>] (__cgroup_procs_write) from [<c01d43c4>] (cgroup_tasks_write+0x1c/0x24)
[<c01d43c4>] (cgroup_tasks_write) from [<c01cec4c>] (cgroup_file_write+0x40/0x104)
[<c01cec4c>] (cgroup_file_write) from [<c02ee920>] (kernfs_fop_write+0x104/0x208)
[<c02ee920>] (kernfs_fop_write) from [<c0275a40>] (vfs_write+0xa4/0x1ac)
[<c0275a40>] (vfs_write) from [<c0276b8c>] (SyS_write+0x54/0xb8)
[<c0276b8c>] (SyS_write) from [<c0107f9c>] (__sys_trace_return+0x0/0x10)
---[ end trace 8e36fa43c00993cb ]---
init: Service 'exec 6 (/system/bin/bootstat)' (pid 952) exited with status 0
init: Starting service 'exec 7 (/system/bin/bootstat)'...
init: Service 'exec 7 (/system/bin/bootstat)' (pid 955) exited with status 0
***   GPU DRV CONFIG   ***
Galcore options:
  irqLine           = 20
  registerMemBase   = 0x00130000
  registerMemSize   = 0x00004000
  irqLine2D         = 21
  registerMemBase2D = 0x00134000
  registerMemSize2D = 0x00004000
  irqLineVG         = 22
  registerMemBaseVG = 0x02204000
  registerMemSizeVG = 0x00004000
  contiguousSize    = 0x08000000
  contiguousBase    = 0x00000000
  bankSize          = 0x00000000
  fastClear         = -1
  compression       = -1
  signal            = 48
  powerManagement   = 1
  baseAddress       = 0x10000000
  physSize          = 0x80000000
  logFileSize       = 0 KB
  recovery          = 0
  stuckDump         = 0
  gpuProfiler       = 0
  irqs              = -1,
-1, -1,
-1, -1,
-1, -1,
-1, -1,
-1,
  registerBases     = 0x00000000,
0x00000000, 0x00000000,
0x00000000,
  registerSizes     = 0x00000800,
0x00000800, 0x00000800,
0x00000800,
  chipIDs     = 0xFFFFFFFF,
0xFFFFFFFF, 0xFFFFFFFF,
0xFFFFFFFF,
Build options:
  gcdGPU_TIMEOUT    = 20000
  gcdGPU_2D_TIMEOUT = 20000
  gcdINTERRUPT_STATISTIC = 1
GPU[0](ChipModel=0x2000 ChipRevision=0xffff5450):
***   GPU STATE DUMP   ***
  axi      = 0x00000079
  idle     = 0x7FFFFFFE
    FE not idle
  DMA appears to be stuck at this address:
    0xFFDA4470
  dmaLow   = 0x00000000
  dmaHigh  = 0x00000000
  dmaState = 0x00000900
    command state       = 0 (PAR_IDLE_ST)
    command DMA state   = 1 (CMD_START_ST)
    command fetch state = 2 (FET_VALID_ST)
    DMA request state   = 0 (REQ_IDLE_ST)
    cal state           = 0 (CAL_IDLE_ST)
    VE request state    = 0 (VER_IDLE_ST)
  Debug registers:
    RA[0] debug registers:
    [00] 046608DC 011ADCE4 011ADCE4 000009C0 03FF0000 00001A00 81B28000 68100000
    [08] 00000000 00000000 00000000 00000000 00000030 01836A40 69F297B1 00000000
    [10] 0746C1F2 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [18] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [20] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [28] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [30] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [38] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [40] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [48] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [50] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [58] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [60] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [68] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [70] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [78] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [80] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [88] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [90] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [98] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [A0] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [A8] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [B0] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [B8] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [C0] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [C8] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [D0] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [D8] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [E0] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [E8] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [F0] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    [F8] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
    TX[0] debug registers:
    [00] 0205CDF8 00000000 00000000 0205CDF8 00001FE7 00103611 0081B088 00103515
    [08] 0081A8A8 12211221 12211221 12211221 12211221 12211221 12211221 12211221
    [10] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
    [18] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
    [20] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
    [28] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
    [30] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
    [38] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
    [40] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
    [48] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
    [50] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
    [58] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
    [60] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
    [68] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
    [70] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
    [78] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
    FE[0] debug registers:
    [00] FFDA4478 42000000 DEADDEAD 00000256 05D0069F 00000001 08044AB9 00003545
    [08] 0000000E 0000166C 000003D0 0000166C 00000688 A340F7BD 000000B0 BABEF00D
    [10] 000009CC 0006D2F2 782766E1 45674567 45674567 45674567 45674567 45674567
    [18] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [20] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [28] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [30] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [38] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [40] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [48] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [50] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [58] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [60] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [68] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [70] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [78] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [80] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [88] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [90] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [98] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [A0] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [A8] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [B0] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [B8] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [C0] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [C8] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [D0] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [D8] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [E0] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [E8] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [F0] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    [F8] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
    PE[0] debug registers:
    [00] 00000000 00000000 02330473 00000000 00000000 00000000 00000000 00000000
    [08] D0004B00 20004B00 9D82328C 11111100 22222200 33333300 44444400 00000000
    [10] 00000000 00000000 00000000 00000000 00000000 DEADBF18 BABEF00D BABEF00D
    [18] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [20] 0000000C 00000080 00000080 003B007F 00002000 00000000 00000000 00000000
    [28] 00000000 003B007F 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
    [30] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [38] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [40] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [48] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [50] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [58] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [60] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [68] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [70] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [78] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [80] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [88] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [90] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [98] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [A0] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [A8] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [B0] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [B8] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [C0] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [C8] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [D0] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [D8] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [E0] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [E8] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [F0] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    [F8] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
    PE[1] debug registers:
    [00] 00000000 00000000 02330469 00000000 00000000 00000000 00000000 00000000
    [10] 00000000 00000000 00000000 00000000 00000000 DEADBF03 BABEF00D BABEF00D
    [20] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [28] 00000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
    DE[0] debug registers:
    [00] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [08] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [10] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [18] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [28] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [30] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [38] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [40] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [48] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [50] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [58] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [60] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [68] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [70] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [78] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [80] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [88] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [90] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [98] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [A0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [A8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [B0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [B8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [C0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [C8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [D0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [D8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [E0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [E8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [F0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [F8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    SH[0] debug registers:
    [00] B2FFE823 555FC000 00080005 00010822 2A92AF00 00452416 00450416 00D30F0B
    [08] 01CF17FA 0000FD93 0000166C 00000000 00000000 00000000 00817410 2AB97995
    [10] 0415F812 2458A5D8 03F44B94 00F36E7C 005FBD51 010B58AF 071B040F 06088D53
    [18] 2A313476 00038626 072D78F8 BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [20] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [28] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [30] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [38] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [40] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [48] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [50] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [58] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [60] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [68] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [70] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [78] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [80] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [88] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [90] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [98] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [A0] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [A8] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [B0] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [B8] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [C0] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [C8] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [D0] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [D8] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [E0] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [E8] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [F0] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
    [F8] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D DEADBEEF
    PA[0] debug registers:
    SE[0] debug registers:
    [00] 0A8550A8 01555555 15555555 05555540 05555555 00002501 00400800 00000000
    [08] A2B0ABC7 05BD9F21 00000A44 000009C0 00000000 00000000 051DCB9E 0000027D
    [10] 00000000 00000084 00000000 00000000 014BA4BF 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [18] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [20] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [28] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [30] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [38] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [40] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [48] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [50] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [58] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [60] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [68] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [70] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [78] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [80] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [88] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [90] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [98] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [A0] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [A8] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [B0] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [B8] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [C0] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [C8] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [D0] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [D8] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [E0] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [E8] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [F0] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    [F8] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
    MC[0] debug registers:
    [00] 00000000 00000000 00000000 00000000 00000000 00000000 FE0500B0 000C22E0
    [08] 000C22E0 0A912D2E 0001845C 01522617 110F60C4 00000000 001C480B 00000000
    [18] 00000000 02002022 1FCDFC30 12345678 12345678 12345678 12345678 12345678
    [20] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [28] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [30] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [38] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [40] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [48] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [50] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [58] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [60] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [68] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [70] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [78] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [80] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [88] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [90] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [98] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [A0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [A8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [B0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [B8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [C0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [C8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [D0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [D8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [E0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [E8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [F0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    [F8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
    MC[1] debug registers:
    [00] FE0500B0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [18] 00000000 00000000 1FCDFC30 12345678 12345678 12345678 12345678 12345678
    HI[0] debug registers:
    [00] 000506C9 08B84C83 03AB3B84 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [08] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [10] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [18] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [20] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [28] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [30] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [38] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [40] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [48] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [50] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [58] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [60] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [68] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [70] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [78] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [80] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [88] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [90] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [98] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [A0] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [A8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [B0] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [B8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [C0] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [C8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [D0] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [D8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [E0] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [E8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [F0] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    [F8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
    TPG[1] debug registers:
    TFB[1] debug registers:
    USC[1] debug registers:
    L2[0] debug registers:
    BLT[0] debug registers:
    Other Registers[0]:
      [0x0040] 0x000F7AB0
      [0x0044] 0x00000F49
      [0x004C] 0x00000F49
      [0x0050] 0x00000409
      [0x0054] 0x00000409
      [0x0058] 0x000F7AB0
      [0x005C] 0x0005DF2D
      [0x0060] 0x0005DF2D
      [0x043C] 0x00000000
      [0x0440] 0x00000000
      [0x0444] 0x00000000
      [0x0414] 0x3C000000
      [0x0100] 0x00140021
    MMU status from MC[0]:
***   MMU ERROR DUMP   ***
  MMU status = 0x00000000
    Other Registers[1]:
      [0x0040] 0x00136365
      [0x0044] 0x001C0350
      [0x004C] 0x001C0350
      [0x0050] 0x000700D4
      [0x0054] 0x000700D4
      [0x0058] 0x00136365
      [0x005C] 0x0006D954
      [0x0060] 0x0006D954
      [0x043C] 0x00000000
      [0x0440] 0x00000000
      [0x0444] 0x00000000
      [0x0414] 0x3C000000
      [0x0100] 0x00140021
    MMU status from MC[1]:
    Link stack:
      [0x00] 0xA340F7BA [0x01] 0xA340F7BA [0x02] 0xA340F7BA [0x03] 0xA340F7BC
      [0x04] 0xA340F7BD [0x05] 0xA340F7C1 [0x06] 0xA340F7C1 [0x07] 0xA340F7C1
      [0x08] 0xA340F7C1 [0x09] 0xA340F7C1 [0x0A] 0xA340F7C1 [0x0B] 0xA340F7C1
      [0x0C] 0xA340F7C3 [0x0D] 0x8340F7C5 [0x0E] 0xBFFB4801 [0x0F] 0xA340F7BA
  PRE_STACK:
  CMD_STACK:
  LINK_STACK:
*****   SW COUNTERS  *****
    Execute Count = 0x000003A8
    Execute Addr  = 0x1A07BE28
    End     Addr  = 0x1A07BE20
CPU: 0 PID: 130 Comm: kworker/u8:1 Tainted: G        W       4.9.17-svn30 #2
Workqueue: galcore workqueue _TimerFunction
[<c0bc11d0>] (dump_stack) from [<c0868c90>] (gckOS_DumpCallStack+0x8/0x10)
[<c0868c90>] (gckOS_DumpCallStack) from [<c088ff14>] (gckHARDWARE_DumpGPUState+0x830/0xa2c)
[<c088ff14>] (gckHARDWARE_DumpGPUState) from [<c086ecf8>] (_DumpState+0x10/0x2c)
[<c086ecf8>] (_DumpState) from [<c086fb10>] (gckKERNEL_Recovery+0x130/0x16c)
[<c086fb10>] (gckKERNEL_Recovery) from [<c086fd00>] (_MonitorTimerFunction+0x1b4/0x1c4)
[<c086fd00>] (_MonitorTimerFunction) from [<c014fe5c>] (process_one_work+0x14c/0x4e8)
[<c014fe5c>] (process_one_work) from [<c0150230>] (worker_thread+0x38/0x544)
[<c0150230>] (worker_thread) from [<c0156820>] (kthread+0xec/0x104)
[<c0156820>] (kthread) from [<c0107eb8>] (ret_from_fork+0x14/0x3c)
**** COMMAND BUF DUMP ****
  Submitted commit stamp = 643
  Executed commit stamp  = 637
DMA Address 0xFFDA4470, memory around:
User Command Buffer:
FFDA4000 : 08010E00 00000000 08010E02 00000701 48000000 00000701 08010E03 00000C27
FFDA4020 : 08010E03 00000010 08010E02 00000701 48000000 00000701 08010594 00000001
FFDA4040 : 08010E02 00000701 48000000 00000701 08010218 00000000 0801021A 00000011
FFDA4060 : 08010218 00000001 0801021A 00000021 08010E02 00000701 48000000 00000701
FFDA4080 : 08010E05 00000001 08030E06 00000000 00000000 00000000 08020E0A 00000000
FFDA40A0 : 00000000 DEADDEAD 08020E0D 00000000 00000000 DEADDEAD 08010E15 00000000
FFDA40C0 : 08010E13 00000000 08100180 00000000 00000000 00000000 00000000 00000000
FFDA40E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA4100 : 00000000 00000000 00000000 DEADDEAD 084001B0 00000000 00000000 00000000
FFDA4120 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA4140 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA4160 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA4180 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA41A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA41C0 : 00000000 00000000 00000000 00000000 00000000 3F800000 3F800000 3F800000
FFDA41E0 : 3F800000 3F800000 3F800000 3F800000 3F800000 3F800000 3F800000 3F800000
FFDA4200 : 3F800000 3F800000 3F800000 3F800000 3F800000 DEADDEAD 08305180 00000000
FFDA4220 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA4240 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA4260 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA4280 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA42A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA42C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 DEADDEAD
FFDA42E0 : 08020191 00000000 00000000 DEADDEAD 00030000 00000000 00000000 FFFFFFFF
FFDA4300 : 08010218 00000000 0802021A 00000000 00000000 DEADDEAD 08010C13 00000000
FFDA4320 : 0801040A 00000000 08010224 00000000 08010413 00000000 08030201 00000000
FFDA4340 : 00000001 00000000 0801020C 00000000 08080204 00000000 00000000 00000000
FFDA4360 : 00000000 00000000 00000000 00000000 00000000 DEADDEAD 0C020280 00000000
FFDA4380 : 00000000 DEADDEAD 08010282 00000000 0C020283 00000000 00000000 DEADDEAD
FFDA43A0 : 08030285 00000000 00000000 3F000000 00060000 00000000 00000000 00000000
FFDA43C0 : 00000000 00000000 00000000 DEADDEAD 080102A0 00000000 0C0102A1 00000000
FFDA43E0 : 080102A3 00000000 080102A2 00000000 08100290 00000000 00000000 00000000
FFDA4400 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA4420 : 00000000 00000000 00000000 00000000 00000000 DEADDEAD 08030E80 00000000
FFDA4440 : 00000000 00000000 0C040300 00000000 00000000 45000000 45000000 DEADDEAD
FFDA4460 : 00040000 00000000 00000000 00000000 42000000 DEADDEAD 0C020308 00000000
FFDA4480 : 00000000 DEADDEAD 08010380 000000F1 08040384 00000000 00000000 00000000
FFDA44A0 : 00000000 DEADDEAD 08010381 00000000 08100390 00000000 00000000 00000000
FFDA44C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA44E0 : 00000000 00000000 00000000 00000000 00000000 DEADDEAD 08010382 17000031
FFDA4500 : 08010389 00000000 08010388 00000000 08010383 00000000 08040401 00000000
FFDA4520 : 00000000 00000000 00000000 DEADDEAD 0802040C 00000000 00000000 DEADDEAD
FFDA4540 : 08020410 00000000 00000000 DEADDEAD 0801040B 00000000 0801040E 00000000
FFDA4560 : 080C0800 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA4580 : 00000000 00000000 00000000 00000000 00000000 DEADDEAD 080C0810 00000000
FFDA45A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA45C0 : 00000000 00000000 00000000 DEADDEAD 080C0820 00000000 00000000 00000000
FFDA45E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA4600 : 00000000 DEADDEAD 080C0830 00000000 00000000 00000000 00000000 00000000
FFDA4620 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 DEADDEAD
FFDA4640 : 080C0840 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA4660 : 00000000 00000000 00000000 00000000 00000000 DEADDEAD 080C0850 00000000
FFDA4680 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA46A0 : 00000000 00000000 00000000 DEADDEAD 080C0860 00000000 00000000 00000000
FFDA46C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA46E0 : 00000000 DEADDEAD 080C0870 00321000 00321000 00321000 00321000 00321000
FFDA4700 : 00321000 00321000 00321000 00321000 00321000 00321000 00321000 DEADDEAD
FFDA4720 : 080C0880 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA4740 : 00000000 00000000 00000000 00000000 00000000 DEADDEAD 080C0890 00000000
FFDA4760 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA4780 : 00000000 00000000 00000000 DEADDEAD 080C0900 00000000 00000000 00000000
FFDA47A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FFDA47C0 : 00000000 DEADDEAD 080C0910 00000000 00000000 00000000 00000000 00000000
FFDA47E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 DEADDEAD
FFDA4800 : 080C0920 00000000 00000000 00000000 00000000 00000000 00000000 00000000
I have also seen, after some time of the console, the system goes to a suspend.
PM: Syncing filesystems ... done.
Freezing user space processes ... PM: Wakeup pending, aborting suspend
active wakeup source: PowerManagerService.WakeLocks
Freezing of tasks aborted after 0.009 seconds
Restarting tasks ... done.
PM: suspend exit 1970-01-01 00:07:22.800861008 UTC
PM: suspend entry 1970-01-01 00:07:22.906211342 UTC
Freezing user space processes ... (elapsed 0.002 seconds) done.
Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
PM: suspend of devices complete after 82.994 msecs
PM: suspend devices took 0.090 seconds
PM: late suspend of devices complete after 1.267 msecs
PM: noirq suspend of devices complete after 1.373 msecs
Disabling non-boot CPUs ...
IRQ17 no longer affine to CPU1
CPU1: shutdown
CPU0: update max cpu_capacity 1024
CPU2: shutdown
CPU3: shutdown
rostyslavkhudol
Hi there,
We're experiencing the same issue with iMX6DP. DDR is calibrated. Could someone please recommend how to debug this issue?
manjunathjoshi
Contributor V
Hi Igor,
The board is tested with latest linux 4.1 and is perfectly fine.
Hi Manjunath
how did you flash images, please use Mfg Tool.
manjunathjoshi
Contributor V
I am using MfgTool to flash.
are you able to run successfully previous android releases.
manjunathjoshi
Contributor V
No Igor, I didn't try it on MX6QP. It is the first time. What i wanted to know from you is, the usual cause for such issue as it is in the log, so that I would try debugging in that way. I wanted to know when such issue may usually occur? I understand DDR calibration and how it can help. Similar way i want to understand.
can you please help?
from log : "SMARC Device Board" - are you using SMARC
board (or design based on that board) - in such case nxp android will not
run on it (it was designed for nxp boards).
nxp_com
I have a board that is not a demoboard, it is an Axel Lite and it has the old version of Android.
I am trying to get either Android N or O running and what I have is basic subsystem but video is really an issue.
(Kernel hang when loading the video accelerator)
Is it possible that the provided SW  eg: android_N7.1.2_2.0.0_source
is incompatible with a board that was running Android previously ?
NOTE: I am talking about the VIDEO driver, the rest of the system is OK
NXP does not support "Axel Lite" board and its software,
please apply to board vendor support for updated software.
NXP supports only own demo boards with BSPs described on
i.MX Software|NXP
manjunathjoshi
Contributor V
Hello Igor,
I tried as you mentioned with new DDR calibrated u-boot. Result is same. I get crash on every boot.
Let me know you have any inputs with the logs. I am not able to make out much.
Hi Manjunath
please try to boot linux to test board hardware
Hi Manjunath
please try nxp official android release described on
http://www.nxp.com/products/software-and-tools/software-development-tools/i.mx-software-and-tools/i....
Source code:
https://www.nxp.com/webapp/Download?colCode=IMX_N7.1.2_2.0.0_ANDROID_SOURCE_BSP&appType=license&loca...
manjunathjoshi
Contributor V
Hello Igor,
I am using the N7.1.2 release latest from NXP. I have downloaded the source from the same path as you have mentioned.
I do not have any other source that i may try with kernel 4.9.17. Please check.
I need your help.
Thanks for support,
Hi Manjunath
for custom board please first run ddr test
i.MX6/7 DDR Stress Test Tool V2.70
then rebuild image with new calibration settings found from tester
in uboot/../mx6sabresd/mx6qp.cfg
