RT1050, MCUXpresso and Config Tools compatibility
Question asked by Ryan Shuttleworth on Dec 5, 2017
Latest reply on Apr 10, 2018 by Matthias Pimminger
Hello I am using MCUXpresso IDE, version v10.1.0 [Build 589] [2017-11-14] with an MIMXRT1050-EVK SDK, version  2.3.0 (2017-11-16) and MCUXpresso Config Tools build 4.0.0.201711131454.  I am finding that the tool does not appear to be compatible with MCUXpresso projects and does not appear to fully support the RT105x.  The pin configuration editor appears to work but the clock and peripheral configuration tools show the MCU as not supported.
When will MCUXpresso projects and the RT105x be fully supported by the configuration tool?
Thanks.
The Create New Configuration menu suggests that you can use and existing MCUXpresso project:
Create New Config Options
But when an MCUXpresso project is selected the popup below appears.  The Second option gets further but results in the MCU Not Supported messages.
No MCUXpresso project support listed when first option is selected with a path to an MCUXpresso SDK project:
Tool support does not mention MCUXpresso
No clock tool support:
Clock Tool MCU Not supported
No peripheral support:
Peripheral tool no MCU support
