MTP operation in android nougat
lakshmishetty
We are using sabresd board and android nougat 7.1.1 bsp. When testing usb otg as device only internal shared storage is mounting in host pc. We want to mount all the storage devices in host pc. How to implement this android.
Lakshmi shetty
jamesbone
Hello Lakshmi,
Unfortunately this is an Android Limitation, as you can see in this article,  I recommend you that you post your inquiry in an Android Developer Forum.
FYI: You can’t set Transfer files (MTP) as default on Nougat either – The Android Soul
TIC
