imx6q 开机进入home界面无限重启
wangxizhi
系统:android 6.0
公板:imx6qp SABRE-SD
芯片:imx6Q
仿照imx6qp SABRE-SD设计的主板,芯片用imx6q,开机后进入home界面后重启,串口log呈突然中断状态机器重启,log未找到关键信息,请帮忙定位下重启原因,提供下排查方向
jimmychan
what is the different between your board and the sabresd?
do you change the device tree file base on the different of your board?
it reset immediately after the android home comes out? or it reset after android home comes out few minutes ?
wangxizhi
你们没人吗?
