EMVCo algorithm
EMVCo algorithm
sergioa
Hello I like to know if there are same example or documentation of how can i certificate an economical transaction in EMV with PN7462.
thanks in avance
Jonathan_Iglesias
Hope you are doing great, this kind of information  for PN7462 I believe is under NDA the examples can be found in Docstore  you will have to sign an NDA or  get in touch with your locar distributor in order to get the NDA. I believe that there is no need to certificate  the PN7462 because it is already EMV compliant  and NXP does not certificate this is done through EMVco. if you have more questions please let me know.
Have a great day !
Jonathan
