I want execute a *.bat file after building the *.hex image.
When I use the the *.bat file in the Post-build steps, then the *.bat file is executed before the hex-file is created.
How can I start the *.bat file after building the *.hex image automatic in the build process?
BR Lutz
same question@07-30-2021
Hi Lutz,
I didn't find way how to execute post-build after .hex file dump. I'll put feature request for S32DS - In my opinion the post-build step should be really "post-build".
As a workaround you can include hex file dump into your post build .bat file like this (I'm not sure if you are using ARM S32DS - for Power it is similar):
arm-none-eabi-objcopy -O ihex project.elf project.hex
your_post_build_commands
Jiri
