JN5168 Dual antenna design
jiweigao
5168 Dual antenna design?1 for communications in confined space, 2 for communications outside of confined spaces
mario_castaneda
Hi JiWei,
You can use an antenna switch IC, The kw41, for example, has two antennas, but you can only use one, it will depend on the capacitor. The Idea is something like that, but it will work with a switch.
Mario
