"init: untracked pid 2081 killed by signal 9" in TI J6 DRA75x EVM board
Question asked by Suhas Kaundinya on Nov 27, 2017
Latest reply on Nov 28, 2017 by igorpadykov
I am trying to boot the board which is interfaced with a 10.1 inch screen using emmc memory. I have flashed the prebuilt image of Android Lollipop on the emmc memory and I tried to boot it. I even changed the board switches for booting using emmc and for a 10.1 inch screen. It was working fine until I interfaced the board with an HDMI display screen to check on it, but it dint work. So I tried to switch back to the EVM interface and now, I am facing this error. The log is below:
U-Boot 2014.07-00006-g11d734a (Sep 20 2015 - 16:03:17), Build: jenkins-JACINTO6_ubo9
CPU  : DRA752-GP ES1.0
Board: DRA7xx
I2C:   ready
DRAM:  1.5 GiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Using default environment
serial# not set, setting...
SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
     256      128K xloader
     512      384K bootloader
    1280      128K environment
    1536      128K misc
    2560       16M efs
   35328       16K crypto
   35360       10M recovery
   55840       10M boot
   76320      768M system
 1649184      256M cache
 2173472     1024K ipu1
 2175520     1024K ipu2
 2177568     2544M userdata
SCSI:  Net:   <ethaddr> not set. Validating first E-fuse MAC
cpsw
Hit any key to stop autoboot:  0
   Image magic:   ANDROID!XPS
   kernel_size:   0x535058
   kernel_addr:   0x80008000
   rdisk_size:   0xabca1
   rdisk_addr:   0x81f00000
   second_size:   0x0
   second_addr:   0x80f00000
   tags_addr:   0x80000100
   page_size:   0x800
   name:
   cmdline:
   id[0]:   0x9239535f
   id[1]:   0x7ac04048
   id[2]:   0xb4cc528e
   id[3]:   0x45e0d043
   id[4]:   0xed454003
   id[5]:   0x834441a8
   id[6]:   0xb234629
   id[7]:   0x24906a2a
ramdisk sector count:1374kernel  @ 80008000 (5460056)
ramdisk  @ 81f00000 (703649)
Starting kernel...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.14.51 (a0271468@UDA0271468A) (gcc version 4.8 (GCC) 5
[    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c7387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] Machine model: TI DRA742
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, sizeB
[    0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id sl
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, sizeB
[    0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id sl
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, sizeB
[    0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id sl
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, sizeB
[    0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id sl
[    0.000000] cma: CMA: reserved 24 MiB at ae000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] DRA752 ES1.0
[    0.000000] PERCPU: Embedded 8 pages/cpu @ed358000 s8704 r8192 d15872 u32768
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages:4
[    0.000000] Kernel command line: root=/dev/mmcblk0p2 rw console=ttyS0,119200 and
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1351436K/1565696K available (7655K kernel code, 412K rwdata,)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc09f208c   (10153 kB)
[    0.000000]       .init : 0xc09f3000 - 0xc0a4b200   ( 353 kB)
[    0.000000]       .data : 0xc0a4c000 - 0xc0ab3058   ( 413 kB)
[    0.000000]        .bss : 0xc0ab3064 - 0xc0b10dd4   ( 376 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] OMAP clockevent source: timer1 at 32786 Hz
[    0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 65536s
[    0.000030] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000427] Architected cp15 timer(s) running at 6.14MHz (virt).
[    0.000432] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 27945920s
[    0.000439] Switching to timer-based delay loop
[    0.001082] Console: colour dummy device 80x30
[    0.001103] Calibrating delay loop (skipped), value calculated using timer frequ)
[    0.001116] pid_max: default: 32768 minimum: 301
[    0.001223] Security Framework initialized
[    0.001235] SELinux:  Initializing.
[    0.001324] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001334] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.024957] Initializing cgroup subsys debug
[    0.024971] Initializing cgroup subsys freezer
[    0.025009] CPU: Testing write buffer coherency: ok
[    0.025265] /cpus/cpu@0 missing clock-frequency property
[    0.025301] /cpus/cpu@1 missing clock-frequency property
[    0.025312] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.025330] Setting up static identity map for 0x8077fd98 - 0x8077fdf0
[    0.080857] CPU1: Booted secondary processor
[    0.080886] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.081024] Brought up 2 CPUs
[    0.081040] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[    0.081047] CPU: All CPU(s) started in SVC mode.
[    0.081505] devtmpfs: initialized
[    0.082383] VFP support v0.3: implementor 41 architecture 4 part 30 variant f re0
[    0.084046] omap_hwmod: l3_main_2 using broken dt data from ocp
[    0.097022] omap_hwmod: tptc0 using broken dt data from edma-controller
[    0.097514] omap_hwmod: tptc1 using broken dt data from edma-controller
[    0.281011] pinctrl core: initialized pinctrl subsystem
[    0.281778] regulator-dummy: no parameters
[    0.285207] NET: Registered protocol family 16
[    0.286372] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.288503] cpuidle: using governor ladder
[    0.288514] cpuidle: using governor menu
[    0.334598] syscon 4a002000.tisysconcore: regmap [mem 0x4a002000-0x4a0026cf] regd
[    0.334931] syscon 4a002e00.tisyscon: regmap [mem 0x4a002e00-0x4a002e7b] registed
[    0.337675] OMAP GPIO hardware version 0.1
[    0.344018] irq: no irq domain found for /ocp/pinmux@4a003400 !
[    0.350216] platform 58820000.ipu: assigned reserved memory node ipu1_cma@9d00000
[    0.350500] platform 55020000.ipu: assigned reserved memory node ipu2_cma@9580000
[    0.350808] platform 40800000.dsp: assigned reserved memory node dsp1_cma@9900000
[    0.368191] platform 41000000.dsp: assigned reserved memory node dsp2_cma@9f00000
[    0.374679] No ATAGs?
[    0.374705] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint reg.
[    0.374713] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.377787] OMAP DMA hardware revision 0.0
[    0.414676] bio: create slab <bio-0> at 0
[    0.429814] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[    0.436324] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver
[    0.437008] platform fixedregulator-sd: Driver reg-fixed-voltage requests probe l
[    0.437277] evm_3v3_sw: 3300 mV
[    0.437323] reg-fixed-voltage fixedregulator-evm_3v3_sw: Failed to find supply vn
[    0.437509] reg-fixed-voltage fixedregulator-evm_3v3_sw: Failed to register regu7
[    0.437527] platform fixedregulator-evm_3v3_sw: Driver reg-fixed-voltage requestl
[    0.437778] aic_dvdd: 1800 mV
[    0.437831] reg-fixed-voltage fixedregulator-aic_dvdd: Failed to find supply vin
[    0.438015] reg-fixed-voltage fixedregulator-aic_dvdd: Failed to register regula7
[    0.438034] platform fixedregulator-aic_dvdd: Driver reg-fixed-voltage requests l
[    0.438336] vmmcwl_fixed: 1800 mV
[    0.438708] vtt_fixed: 1350 mV
[    0.438757] reg-fixed-voltage fixedregulator-vtt: Failed to find supply vin
[    0.438973] reg-fixed-voltage fixedregulator-vtt: Failed to register regulator: 7
[    0.438991] platform fixedregulator-vtt: Driver reg-fixed-voltage requests probel
[    0.441157] vgaarb: loaded
[    0.441626] i2c-core: driver [palmas] using legacy suspend method
[    0.441636] i2c-core: driver [palmas] using legacy resume method
[    0.442236] SCSI subsystem initialized
[    0.443535] usbcore: registered new interface driver usbfs
[    0.443704] usbcore: registered new interface driver hub
[    0.443893] usbcore: registered new device driver usb
[    0.446279] palmas 0-0058: IRQ missing: skipping irq request
[    0.446629] palmas 0-0058: Muxing GPIO 2e, PWM 0, LED 0
[    0.446775] prom_parse: Bad cell count for /ocp/i2c@48070000/tps659038@58
[    0.448874] smps123: 850 <--> 1250 mV at 1060 mV
[    0.450526] smps45: 850 <--> 1150 mV at 1060 mV
[    0.453543] smps6: 850 <--> 1250 mV at 1250 mV
[    0.455025] smps7: 850 <--> 1060 mV at 1030 mV
[    0.456683] smps8: 850 <--> 1250 mV at 1060 mV
[    0.458169] smps9: 1800 mV
[    0.461293] ldo1: 1800 <--> 3300 mV at 3300 mV
[    0.471567] ldo2: 3300 mV
[    0.481152] ldo3: 1800 mV
[    0.482025] LDO4: at 1800 mV
[    0.482638] LDO5: no parameters
[    0.483232] LDO6: no parameters
[    0.483836] LDO7: no parameters
[    0.484429] LDO8: no parameters
[    0.491179] ldo9: 1050 mV
[    0.501277] ldoln: 1800 mV
[    0.511192] ldousb: 3300 mV
[    0.511908] REGEN1: no parameters
[    0.512453] regen2: no parameters
[    0.513052] sysen1: no parameters
[    0.513643] sysen2: no parameters
[    0.514631] pcf857x 0-0020: probed
[    0.515554] pcf857x 0-0021: probed
[    0.516741] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[    0.517883] pcf857x 1-0026: probed
[    0.519748] omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz
[    0.520172] omap_i2c 48060000.i2c: bus 2 rev0.12 at 3400 kHz
[    0.521355] pcf857x 3-0021: probed
[    0.521379] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
[    0.521711] media: Linux media interface: v0.10
[    0.521862] Linux video capture interface: v2.00
[    0.522091] pps_core: LinuxPPS API ver. 1 registered
[    0.522100] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti>
[    0.522217] PTP clock support registered
[    0.523688] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[    0.524146] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[    0.525258] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[    0.525370] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[    0.525477] omap-iommu 58882000.mmu: 58882000.mmu registered
[    0.525579] omap-iommu 55082000.mmu: 55082000.mmu registered
[    0.525766] omap-iommu 41501000.mmu: 41501000.mmu registered
[    0.525870] omap-iommu 41502000.mmu: 41502000.mmu registered
[    0.526471] Advanced Linux Sound Architecture Driver Initialized.
[    0.528016] Switched to clocksource arch_sys_counter
[    0.547199] NET: Registered protocol family 2
[    0.547897] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.547960] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.548111] TCP: Hash tables configured (established 8192 bind 8192)
[    0.548157] TCP: reno registered
[    0.548169] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.548200] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.548400] NET: Registered protocol family 1
[    0.548662] RPC: Registered named UNIX socket transport module.
[    0.548671] RPC: Registered udp transport module.
[    0.548678] RPC: Registered tcp transport module.
[    0.548685] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.549348] Trying to unpack rootfs image as initramfs...
[    0.579496] Freeing initrd memory: 684K (c1f00000 - c1fab000)
[    0.580182] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters e
[    0.583302] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.583414] audit: initializing netlink subsys (disabled)
[    0.583457] audit: type=2000 audit(0.569:1): initialized
[    0.682428] bounce pool size: 64 pages
[    0.682696] VFS: Disk quotas dquot_6.5.2
[    0.682803] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.683479] NFS: Registering the id_resolver key type
[    0.683516] Key type id_resolver registered
[    0.683524] Key type id_legacy registered
[    0.683554] jffs2: version 2.2. (NAND) (SUMMARY)  �© 2001-2006 Red Hat, Inc.
[    0.683721] fuse init (API version 7.22)
[    0.684049] msgmni has been set to 1462
[    0.686413] NET: Registered protocol family 38
[    0.686441] io scheduler noop registered
[    0.686449] io scheduler deadline registered
[    0.686482] io scheduler cfq registered (default)
[    0.692613] pinctrl-single 4a003400.pinmux: 281 pins at pa fc003400 size 1124
[    0.731077] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[    0.731091] pci_bus 0000:00: root bus resource [io  0x1000-0x10000]
[    0.731102] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[    0.731114] pci_bus 0000:00: No busn resource found for root bus, will use [bus ]
[    0.731615] PCI: bus0: Fast back to back transfers disabled
[    0.731862] PCI: bus1: Fast back to back transfers enabled
[    0.731977] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[    0.731993] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[    0.732006] pci 0000:00:00.0: PCI bridge to [bus 01]
[    0.732026] pci 0000:00:00.0: PCI bridge to [bus 01]
[    0.734321] OMAP DSS rev 6.1
[    0.753542] tlc59108 0-0040: Failed to set MODE1: -121
[    0.753605] tlc59108: probe of 0-0040 failed with error -121
[    0.754877] platform encoder@1: Driver dra7evm-tpd12s015 requests probe deferral
[    0.755581] connector-hdmi connector@1: failed to find video source
[    0.755598] platform connector@1: Driver connector-hdmi requests probe deferral
[    0.756542] pbias_mmc_omap5: 1800 <--> 3000 mV at 3000 mV
[    0.757338] abb_mpu: 1100 <--> 1210 mV
[    0.757709] abb_ivahd: 1060 <--> 1250 mV
[    0.758107] abb_dspeve: 1060 <--> 1250 mV
[    0.758461] abb_gpu: 1060 <--> 1280 mV
[    0.759665] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.764223] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 299, base_baud = 300
[    1.959551] console [ttyS0] enabled
[    1.963843] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 300, base_baud = 300
[    1.973647] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 301, base_baud = 300
[    1.983990] [drm] Initialized drm 1.1.0 20060810
[    1.999443] brd: module loaded
[    2.008092] loop: module loaded
[    2.011502] (stk) :sysfs entries created
[    2.015469] (stk) : debugfs entries created
[    2.019768] (hci_tty): inside hci_tty_init
[    2.024438] (hci_tty): allocated 249, 0
[    2.029951] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[    2.036700] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl e
[    2.045284] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp p
[    2.055965] scsi0 : ahci_platform
[    2.059812] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 8
[    2.069170] mtdoops: mtd device (mtddev=name/number) must be supplied
[    2.080140] tun: Universal TUN/TAP device driver, 1.6
[    2.085214] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.091720] CAN device driver interface
[    2.096813] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=)
[    2.107957] usbcore: registered new interface driver asix
[    2.113544] usbcore: registered new interface driver ax88179_178a
[    2.119828] usbcore: registered new interface driver cdc_ether
[    2.125843] usbcore: registered new interface driver smsc95xx
[    2.131774] usbcore: registered new interface driver net1080
[    2.137592] usbcore: registered new interface driver cdc_subset
[    2.143692] usbcore: registered new interface driver zaurus
[    2.149474] usbcore: registered new interface driver cdc_ncm
[    2.155838] omap-dwc3 48880000.omap_dwc3_1: unable to get extcon device : extcon1
[    2.163759] platform 48880000.omap_dwc3_1: Driver omap-dwc3 requests probe deferl
[    2.171601] omap-dwc3 488c0000.omap_dwc3_2: unable to get extcon device : extcon2
[    2.179510] platform 488c0000.omap_dwc3_2: Driver omap-dwc3 requests probe deferl
[    2.188608] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.195165] ehci-pci: EHCI PCI platform driver
[    2.199785] ehci-omap: OMAP-EHCI Host Controller driver
[    2.205483] usbcore: registered new interface driver cdc_wdm
[    2.211347] usbcore: registered new interface driver usb-storage
[    2.218762] mousedev: PS/2 mouse device common for all mice
[    2.225641] input: LDC 3001 TouchScreen Controller as /devices/44000000.ocp/48070
[    2.237498] i2c-core: driver [rtc-ds1307] using legacy suspend method
[    2.243984] i2c-core: driver [rtc-ds1307] using legacy resume method
[    2.251021] omap_rtc 48838000.rtcss: rtc core: registered 48838000.rtcss as rtc0
[    2.259077] i2c /dev entries driver
[    2.265335] tvp5158 1-0058: Camera sensor driver registered
[    2.271563] ov1063x 1-0037: Failed writing register 0x0103!
[    2.277170] ov1063x: probe of 1-0037 failed with error -121
[    2.283587] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[    2.289772] vip 48970000.vip: No explicit pinctrl resources data.
[    2.296844] vip 48970000.vip: loading firmware vpdma-1b8.bin
[    2.303003] DRA7xx Radio probe done
[    2.306951] Driver for 1-wire Dallas network protocol.
[    2.312457] vpe 489d0000.vpe: Device registered as /dev/video0
[    2.318344] vip 48970000.vip: VPDMA firmware loaded
[    2.323338] vip1-s0: Using subdev tvp5158 1-0058 for capture
[    2.329445] vip1-s0: vip Device registered as /dev/video1
[    2.335155] coproc iva_coproc: probe
[    2.335220] vip1-s0: vip Device registered as /dev/video2
[    2.335516] vip1-s0: vip Device registered as /dev/video3
[    2.335818] vip1-s0: vip Device registered as /dev/video4
[    2.335835] vip1-s1: Port A enabled but no endpoints found
[    2.335841] vip1-s0: Port B enabled but no endpoints found
[    2.366163] vip1-s1: Port B enabled but no endpoints found
[    2.366164] Adding alias for supply vdd,iva_coproc -> vdd,4a0025cc.voltdm
[    2.378602] Adding alias for supply vbb,iva_coproc -> vbb,4a0025cc.voltdm
[    2.386554] coproc iva_coproc: coproc_probe result=0
[    2.391592] coproc dsp_coproc: probe
[    2.395261] Adding alias for supply vdd,dsp_coproc -> vdd,4a0025e0.voltdm
[    2.398047] ata1: SATA link down (SStatus 0 SControl 300)
[    2.407533] Adding alias for supply vbb,dsp_coproc -> vbb,4a0025e0.voltdm
[    2.415415] coproc dsp_coproc: coproc_probe result=0
[    2.421160] ti-soc-thermal 4a0021e0.bandgap: Non-trimmed BGAP, Temp not accurate
[    2.428613] ti-soc-thermal 4a0021e0.bandgap: Non-trimmed BGAP, Temp not accurate
[    2.436041] ti-soc-thermal 4a0021e0.bandgap: Non-trimmed BGAP, Temp not accurate
[    2.443483] ti-soc-thermal 4a0021e0.bandgap: Non-trimmed BGAP, Temp not accurate
[    2.450928] ti-soc-thermal 4a0021e0.bandgap: Non-trimmed BGAP, Temp not accurate
[    2.461792] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    2.470493] omap_hsmmc 4809c000.mmc: unable to get vmmc regulator -517
[    2.477131] platform 4809c000.mmc: Driver omap_hsmmc requests probe deferral
[    2.484653] omap_hsmmc 480b4000.mmc: unable to get vmmc regulator -517
[    2.491288] platform 480b4000.mmc: Driver omap_hsmmc requests probe deferral
[    2.619834] ledtrig-cpu: registered to indicate activity on CPUs
[    2.628265] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[    2.634668] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[    2.641070] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[    2.648060] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[    2.656426] hidraw: raw HID events driver (C) Jiri Kosina
[    2.662190] usbcore: registered new interface driver usbhid
[    2.667785] usbhid: USB HID core driver
[    2.680276] ion_chunk_heap_create: base 2881486848 size 4194304 align 16384
[    2.687969] ashmem: initialized
[    2.692833]  remoteproc0: 58820000.ipu is available
[    2.697732]  remoteproc0: Note: remoteproc is still under development and consid.
[    2.706752]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward c.
[    2.717348]  remoteproc0: Direct firmware load failed with error -2
[    2.723776]  remoteproc1: 55020000.ipu is available
[    2.728692]  remoteproc1: Note: remoteproc is still under development and consid.
[    2.737688]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward c.
[    2.748129]  remoteproc0: Falling back to user helper
[    2.748249]  remoteproc1: Direct firmware load failed with error -2
[    2.748253]  remoteproc1: Falling back to user helper
[    2.748469]  remoteproc2: 40800000.dsp is available
[    2.748472]  remoteproc2: Note: remoteproc is still under development and consid.
[    2.748475]  remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward c.
[    2.748879]  remoteproc3: 41000000.dsp is available
[    2.748882]  remoteproc3: Note: remoteproc is still under development and consid.
[    2.748885]  remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward c.
[    2.749150]  remoteproc2: Direct firmware load failed with error -2
[    2.749153]  remoteproc2: Falling back to user helper
[    2.749398]  remoteproc3: Direct firmware load failed with error -2
[    2.749402]  remoteproc3: Falling back to user helper
[    2.840956] tlv320aic3x-codec 0-0019: Failed to get supply 'IOVDD': -517
[    2.847688] tlv320aic3x-codec 0-0019: Failed to request supplies: -517
[    2.854367] i2c 0-0019: Driver tlv320aic3x-codec requests probe deferral
[    2.861306] tlv320aic3x-codec 1-0018: Failed to get supply 'IOVDD': -517
[    2.868053] tlv320aic3x-codec 1-0018: Failed to request supplies: -517
[    2.874702] i2c 1-0018: Driver tlv320aic3x-codec requests probe deferral
[    2.881630] tlv320aic3x-codec 1-0019: Failed to get supply 'IOVDD': -517
[    2.888387] tlv320aic3x-codec 1-0019: Failed to request supplies: -517
[    2.895036] i2c 1-0019: Driver tlv320aic3x-codec requests probe deferral
[    2.901955] tlv320aic3x-codec 1-001a: Failed to get supply 'IOVDD': -517
[    2.908712] tlv320aic3x-codec 1-001a: Failed to request supplies: -517
[    2.915359] i2c 1-001a: Driver tlv320aic3x-codec requests probe deferral
[    2.922552] platform bt_sco_card: Driver asoc-simple-card requests probe deferral
[    2.930829] asoc-simple-card asoc-simple-card.0:  hdmi-hifi <-> 58040000.encoderk
[    2.940815] davinci-mcasp 48464000.mcasp: DAI is shared
[    2.946618] davinci-mcasp 48468000.mcasp: numevt will be ignored due to errata i8
[    2.955463] davinci-mcasp 48474000.mcasp: DAI is shared
[    2.961086] davinci-mcasp 48474000.mcasp: numevt will be ignored due to errata i8
[    2.969247] davinci-mcasp 48478000.mcasp: numevt will be ignored due to errata i8
[    2.977390] davinci-mcasp 4847c000.mcasp: numevt will be ignored due to errata i8
[    2.985805] davinci_evm primary_sound: ASoC: CODEC (null) not registered
[    2.992581] davinci_evm primary_sound: snd_soc_register_card failed (-517)
[    2.999510] platform primary_sound: Driver davinci_evm requests probe deferral
[    3.007257] dra7xx-jamr3-snd jamr3_sound: ASoC: CODEC (null) not registered
[    3.014297] dra7xx-jamr3-snd jamr3_sound: failed to register sound card -517
[    3.021400] platform jamr3_sound: Driver dra7xx-jamr3-snd requests probe deferral
[    3.029851] oprofile: using timer interrupt.
[    3.034210] u32 classifier
[    3.036928]     Actions configured
[    3.040362] Netfilter messages via NETLINK v0.30.
[    3.045130] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    3.051552] ctnetlink v0.93: registering with nfnetlink.
[    3.057593] xt_time: kernel timezone is -0000
[    3.062251] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.067723] arp_tables: (C) 2002 David S. Miller
[    3.072417] TCP: cubic registered
[    3.075745] Initializing XFRM netlink socket
[    3.080135] NET: Registered protocol family 10
[    3.085343] mip6: Mobile IPv6
[    3.088369] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.093947] sit: IPv6 over IPv4 tunneling driver
[    3.099528] NET: Registered protocol family 17
[    3.104010] NET: Registered protocol family 15
[    3.108555] Bridge firewalling registered
[    3.112583] can: controller area network core (rev 20120528 abi 9)
[    3.118861] NET: Registered protocol family 29
[    3.123332] can: raw protocol (rev 20120528)
[    3.127619] can: broadcast manager protocol (rev 20120528 t)
[    3.133322] can: netlink gateway (rev 20130117) max_hops=1
[    3.138896] 8021q: 802.1Q VLAN Support v1.8
[    3.143128] Key type dns_resolver registered
[    3.147417] NET: Registered protocol family 41
[    3.152682] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.voltdm
[    3.159002] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.voltdm
[    3.166678] Power Management for TI OMAP4+ devices.
[    3.171803] ThumbEE CPU extension supported.
[    3.176100] Registering SWP/SWPB emulation handler
[    3.183113] vmmcwl_fixed: disabling
[    3.186613] regulator-dummy: disabling
[    3.190575] dmm 4e000000.dmm: workaround for errata i878 in use
[    3.198241] dmm 4e000000.dmm: initialized all PAT entries
[    3.204008] platform omapdrm.0: Driver omapdrm requests probe deferral
[    3.211983] evm_3v3_sd: 3300 mV
[    3.215496] evm_3v3_sw: 3300 mV
[    3.218777] evm_3v3_sw: supplied by sysen1
[    3.223308] aic_dvdd: 1800 mV
[    3.226402] aic_dvdd: supplied by evm_3v3_sw
[    3.230994] vtt_fixed: 1350 mV
[    3.234169] vtt_fixed: supplied by sysen2
[    4.041717] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.047438] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus numbe1
[    4.055467] xhci-hcd xhci-hcd.0.auto: irq 439, io mem 0x488d0000
[    4.061636] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.068487] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.075737] usb usb1: Product: xHCI Host Controller
[    4.080665] usb usb1: Manufacturer: Linux 3.14.51 xhci-hcd
[    4.086171] usb usb1: SerialNumber: xhci-hcd.0.auto
[    4.091602] hub 1-0:1.0: USB hub found
[    4.095384] hub 1-0:1.0: 1 port detected
[    4.099548] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.105245] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus numbe2
[    4.113077] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    4.119910] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.127160] usb usb2: Product: xHCI Host Controller
[    4.132066] usb usb2: Manufacturer: Linux 3.14.51 xhci-hcd
[    4.137572] usb usb2: SerialNumber: xhci-hcd.0.auto
[    4.142983] hub 2-0:1.0: USB hub found
[    4.146765] hub 2-0:1.0: 1 port detected
[    4.231457] asoc-simple-card bt_sco_card:  bt-sco-pcm <-> 48478000.mcasp mappingk
[    4.243375] davinci_evm primary_sound:  tlv320aic3x-hifi <-> 48468000.mcasp mappk
[    4.261174] dra7xx-jamr3-snd jamr3_sound:  multicodec <-> 48474000.mcasp mappingk
[    4.270055] platform omapdrm.0: Driver omapdrm requests probe deferral
[    4.288094] mmc2: BKOPS_EN bit is not set
[    4.294604] mmc2: new high speed DDR MMC card at address 0001
[    4.300732] mmcblk0: mmc2:0001 MMC04G 3.52 GiB
[    4.305401] mmcblk0boot0: mmc2:0001 MMC04G partition 1 16.0 MiB
[    4.311485] mmcblk0boot1: mmc2:0001 MMC04G partition 2 16.0 MiB
[    4.318026] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[    4.324245] davinci_mdio 48485000.mdio: detected phy mask fffffff3
[    4.334628] libphy: 48485000.mdio: probed
[    4.338698] Alternate GPT is invalid, using primary GPT.
[    4.344057]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
[    4.350109] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver n
[    4.358191] davinci_mdio 48485000.mdio: phy[3]: device 48485000.mdio:03, driver n
[    4.366357] platform omapdrm.0: Driver omapdrm requests probe deferral
[    4.373433] platform omapdrm.0: Driver omapdrm requests probe deferral
[    4.380291] cpsw 48484000.ethernet: Random MACID = 56:b6:f6:56:29:51
[    4.387771] cpsw 48484000.ethernet: cpsw: Random MACID = 8e:85:72:a8:e6:4b
[    4.395733] platform omapdrm.0: Driver omapdrm requests probe deferral
[    4.402783] file system registered
[    4.407387]  mmcblk0boot1: unknown partition table
[    4.412758] Number of LUNs=8
[    4.415666] Mass Storage Function, version: 2009/09/11
[    4.420872] LUN: removable file: (no medium)
[    4.425631] android_usb gadget: android_usb ready
[    4.430430]  mmcblk0boot0: unknown partition table
[    4.430451] dwc3 48890000.usb: otg: usb_otg_register_gadget: device not registere
[    4.444461] omap_rtc 48838000.rtcss: setting system clock to 2000-01-01 00:00:01)
[    4.444596] platform omapdrm.0: Driver omapdrm requests probe deferral
[    4.470213] ALSA device list:
[    4.473195]   #0: DRA7xx-EVM
[    4.476082]   #1: HDMI 58040000.encoder
[    4.480180]   #2: DRA7xx-WiLink
[    4.483330]   #3: DRA7xx-JAMR3
[    4.486767] Freeing unused kernel memory: 352K (c09f3000 - c0a4b000)
[    4.543519] audit: type=1403 audit(946684801.589:2): policy loaded auid=429496725
[    4.813756] init: /dev/hw_random not found
[    4.823786] init: /dev/hw_random not found
[    4.836697] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts)
[    4.844939] fs_mgr: __mount(source=/dev/block/mmcblk0p9,target=/system,type=ext40
[    4.859002] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts)
[    4.867201] fs_mgr: __mount(source=/dev/block/mmcblk0p5,target=/factory,type=ext0
[    4.876752] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
[    4.961181] EXT4-fs (mmcblk0p10): recovery complete
[    4.967196] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opto
[    4.977927] fs_mgr: check_fs(): mount(/dev/block/mmcblk0p10,/cache,ext4)=0
[    5.055548]  remoteproc1: powering up 55020000.ipu
[    5.056190] fs_mgr: Running /system/bin/e2fsck on /dev/block/mmcblk0p10
[    5.067117]  remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3472676
[    5.074423] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[    5.128292]  remoteproc1: remote processor 55020000.ipu is now up
[    5.134918] virtio_rpmsg_bus virtio0: rpmsg host is online
[    5.140559]  remoteproc1: registered virtio0 (type 7)
[    5.140768] platform omapdrm.0: Driver omapdrm requests probe deferral
[    5.143775] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x3b
[    5.144219] rpmsg_rpc rpmsg0: probing service rpmsg-dce with src 1024 dst 59
[    5.144962] platform omapdrm.0: Driver omapdrm requests probe deferral
[    5.145229] rpmsg_rpc rpmsg0: published functions = 8
[    5.190603] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[    5.195261] e2fsck: cache: clean, 15/16384 files, 2094/65536 blocks
[    5.214376] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opt)
[    5.222731] fs_mgr: __mount(source=/dev/block/mmcblk0p10,target=/cache,type=ext40
[    5.231597] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[    5.640457] EXT4-fs (mmcblk0p13): 1 orphan inode deleted
[    5.645794] EXT4-fs (mmcblk0p13): recovery complete
[    6.183311] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opto
[    6.194060] fs_mgr: check_fs(): mount(/dev/block/mmcblk0p13,/data,ext4)=0
[    6.250289] fs_mgr: Running /system/bin/e2fsck on /dev/block/mmcblk0p13
[    6.288470] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[    6.293052] e2fsck: /dev/block/mmcblk0p13: clean, 515/162880 files, 23084/651452s
[    6.312460] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opt)
[    6.320751] fs_mgr: __mount(source=/dev/block/mmcblk0p13,target=/data,type=ext4)0
[    6.402613]  remoteproc2: failed to load dra7-dsp1-fw.xe66
[    6.413759] binder: 1933:1933 transaction failed 29189, size 0-0
[    6.429116]  remoteproc3: failed to load dra7-dsp2-fw.xe66
[    6.494307]  remoteproc0: failed to load dra7-ipu1-fw.xem4
[    6.530140] Loading modules backported from Linux version R8.6-0-g3f5b34f
[    6.537049] Backport generated by backports.git R8.6-0-g4677dc3
[    6.715564] platform omapdrm.0: Driver omapdrm requests probe deferral
[    6.737790] logd.auditd: start
[    6.740640] cfg80211: Calling CRDA to update world regulatory domain
[    6.917125] cfg80211: World regulatory domain updated:
[    6.922873] cfg80211:  DFS Master region: unset[    6.923556] random: nonblockind
[    6.932824] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, )
[    6.943226] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 )
[    6.952168] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 )
[    6.961174] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 )
[    6.969589] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 )
[    6.977974] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 )
[    7.209532] init: cannot find '/system/bin/debuggerd64', disabling 'debuggerd64'
[    7.217153] init: cannot find '/system/bin/rild', disabling 'ril-daemon'
[    7.227058] init: cannot find '/system/bin/install-recovery.sh', disabling 'flas'
[    7.238485] android_usb: already disabled
[    7.250371] PVR_K: UM DDK-(2917986) and KM DDK-(2917986) match. [ OK ]
[    7.258392] read descriptors
[    7.261292] read strings
[    7.263858] mtp_bind_config
shell@jacinto6evm:/ $ [    7.420596] healthd: No charger supplies found
[    7.425072] healthd: No battery devices found
[    7.873768] init: untracked pid 2081 killed by signal 9
Please help me with this.
Suhas
