S12XHY128 flash driver issue
Question asked by Julie Liu on Nov 28, 2017
Latest reply on Dec 4, 2017 by Julie Liu
Dear friend ,
I am now working on S12XHY128 flash driver.
but now it can not work well.
Here is the code of write function.
tFlashStatus FLASH_RAM_WriteRoutine(tFlashAddress uAddr, u16 uwLen, const u8 FLASH_FAR_POINTER aubData)
    u16 uwNbData;
    u8 ubIdx;
    u8 ubStatus;
    u8 ebStatus;
    tFlashStatus eFlashStatus;
    tFlashBoolean eFlashBoolean;
    eFlashStatus = FLASH_NO_ERROR;
    eFlashBoolean = FLASH_TRUE;
    uwNbData = uwLen;
    /* if no data to write */
    if (uwNbData)
        /* if FDIVLD not set */
        if ((FLASH_FCLKDIV & FLASH_FCLKDIV_FDIVLD_MASK) == 0)
            /* FCLKDIV must be set after each reset. */
            FLASH_FCLKDIV = FLASH_FCLKDIV_CONF;
        /* FCCOB availability check */
        while ((FLASH_FSTAT & FLASH_FSTAT_CCIF_MASK) == 0U)
            /* do nothing */
        if (((FLASH_FSTAT & FLASH_FSTAT_ACCERR_MASK) != 0U) &&
            ((FLASH_FSTAT & FLASH_FSTAT_FPVIOL_MASK) != 0U))
            /*  Clear any error flags  */
            FLASH_FSTAT |= (FLASH_FSTAT_ACCERR_MASK | FLASH_FSTAT_FPVIOL_MASK);
        /* Write the program command and the GPAGE part */
        FLASH_FCCOBIX = 0U;
        FLASH_FCCOBHI = FLASH_PROGRAM_P_FLASH;
        FLASH_FCCOBLO = FLASH_WP_PAGE(uAddr);
        uwtest = FLASH_FCCOB;
        /* Write the 16-bit address part of phrase */
        (FLASH_FCCOBIX)++;
        FLASH_FCCOB = FLASH_WP_ADDR(uAddr);
        uAddr = (tFlashAddress)((u32)uAddr + 8U);
        /*  Fill the 8 bytes    */
        for (ubIdx = 0U; ubIdx < 8U; ubIdx++)
            /* If we still have datas to write */
            if (uwNbData != 0U)
                /* If the byte is pair write the low part
                           else increment FCCOBIX index and write the high part */
                if ((ubIdx % 2U) == 1U)
                    /* Write next data word to CCOB buffer. */
                    FLASH_FCCOBLO = *aubData;
                    aubData++;
                else
                    (FLASH_FCCOBIX)++;
                    FLASH_FCCOBHI = *aubData;
                    aubData++;
                /* Decrement the byte number to write */
                uwNbData--;
            /* Else write 0xFFF in the last byte */
            else
                    FLASH_FCCOBLO = 0xFFU;
                else
                    (FLASH_FCCOBIX)++;
                    FLASH_FCCOBHI = 0xFFU;
        } /* End for(ubIdx = 0; ubIdx< 8;   ubIdx++) */
        ubfstat = FLASH_FSTAT;
        /* Launch command */
        FLASH_FSTAT |= FLASH_FSTAT_CCIF_MASK;
        /* Bit polling for command completion check */
            /* do nothing */
    /* Check the error flags and return the error status */
    if (((FLASH_FSTAT & (u8)(FLASH_FSTAT_ACCERR_MASK | FLASH_FSTAT_MGSTAT0_MASK | FLASH_FSTAT_MGSTAT1_MASK)) != 0U) ||
        (eFlashBoolean == FLASH_FALSE))
        eFlashStatus = FLASH_ACCESS_ERROR;
    else if ((FLASH_FSTAT & FLASH_FSTAT_FPVIOL_MASK) != 0U)
        eFlashStatus = FLASH_PROT_ERROR;
    else
        /* Nothing to do */
    return eFlashStatus;
/*---------------------------{end FLASH_RAM_WriteRoutine}-----------------------------*/
But it does not work and I have erased before the write action.
The address I used is global address like  following pic:
Does anyone know what is wrong and do you have sample code for me to reference?
Thanks a lot for your help.
br,
julie
