Does PN7462 has firmware already? or the customer will flash a firmware on it?
lestergonzaga
Hi NXP community
I'm new in designing NFC circuitry. I have the PN7462 on my circuit with its circuit implementation (with antenna). Does PN7462 have already a working firmware flashed already? or the customer must flash a firmware to it? Since I heard there are tools in doing it like MCUxpresso.
Thank You
PN7462
weidong_sun
Hi lester,
 >>Does PN7462 have already a working firmware flashed already?or the
customer must flash a firmware to it? SinceIheard there are tools in
doing it like MCUxpresso.Thank YouPN7462
[Answer] If you are using evaluation board based on PN7462, working firmware has been burned into internal Flash.
But if you are using a new board based PN7462, there is no working firmware in PN7462.
you should write working code and program it into internal Flash of PN7462. Software tool is MCUXpresso IDE , and emulator is LPC-LINK2.
Have a nice day!
TIC weidong sun
